586,290 active members*
4,083 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Coordinate system questions
    Jun 2006
    48
    Is there a way to move (machining) coordinate system or even better ... is it possible to have more than one?
    For example, I have multiple parts to machine in one document and would like to have machining zero set on each of them ...
    For a start would like to move:
    Attachment 320996
    Mar 2016
    58
    Re: Coordinate system questions
    Set a number of parts on your mill and run them as subprograms.
    You usually have 6 coordinate systems on all Fanuc controls, some have more as an option.
    Look at my mill examples on youtube, put in my name, Heinz Putz to see them.
    There are also sub examples on my website: Fanuc CNC programming training. Learn CNC for Fanuc, Yasnac, Mitsubishi CNC controls, CNC Machining Videos and DVD's, CNC programming training, CNC education,and CNC consulting.
    Good luck: Heinz.
    Mar 2010
    813
    Quote Originally Posted by Tomax View Post
    Attachment 320996
    Since you want each part at 0,0 than obviously you will be creating separate toolpaths for each part. just move the part your creating toolpath for to 0,0 once toolpath is saved move and do the same for next.
    Oct 2013
    109
    Hi Tomax. Your post processor can be configured to work in one of two different ways. It can output to all tool paths on work planes as coordinates from global 0,0,0 or it can output them with local Work Plane coordinates. If you get your post configured to do the latter and then program each part on it's own Work Plane with the 0,0,0 of the Work Plane set correctly in relation to the part then you can have as many parts as you want in one drawing that will each be output with it's own local coordinates not coordinates from global.
  1. G68 Coordinate system rotation.
    By Ashish B in forum CNC Machining Centers
    Last Post: 01-07-2013, 11:14 PM
  2. G68.1 Coordinate System Rotation Help
    By SwissPR0 in forum CNC Swiss Screw Machines
    Last Post: 02-03-2011, 08:29 PM
  3. Coordinate System Choice
    By jon_fallon in forum Fadal
    Last Post: 11-03-2008, 07:55 AM
  4. G68 Coordinate Rotation System
    By ebigfoot2 in forum Fanuc
    Last Post: 08-13-2007, 01:33 PM
  5. coordinate system
    By kiethnt in forum G-Code Programing
    Last Post: 04-26-2007, 01:46 PM
