Originally Posted by
Brian L
Yes, this is for "usmcdevildog" and you know more than I from the pictures. My suggestion to him is to MDI the program in and see if it runs. The seller has never run the machine other than jogging and MDI, so doesn't know the procedure and doesn't have the proper things, thumb drives and software.
Just for my own education, I see a Ethernet cable port on the floppy emulator. Could they just hook up an RJ45 cable and then using software on the PC, I use One DNC from the ONE CNC folks myself. But then is it just send thru the RS232 option in the machine?
I ran an ethernet cable from the PC in the back, up to the control pendant, installed a RJ45 port on the side of my pendant and then built an adapter from RJ45 to DB9 to go on the back of the computer. This way I don't have to wander around behind the machine to upload and download my programs.
