Re: Fanuc General Numeric 6 Control and General Questions
It is good you have the OEM and GE Fanuc service manuals for the machine.
The other VERY important item is a list or copy of the parameters, you may have a bubble memory on this model if so they are not so prone to lose, check to see if there is a back-up battery, if so replace it with the power on..
For the oil system, probably needs a new gauge, also often used is a small metering valve/orifice at the end of each lube line and these block over time and need replacing, do not try and clean, they have a gauge No. on them.
The other thing with this age of machine with DC servo's and spindle is to check the brushes, new one's can be had from Helwig Carbon.
The lower operator panel is usually the design of the OEM as opposed to the top Fanuc panel.
If you cannot find which input is which, you can often find it by pushing the button while watching the I/O bit screen and see which input is on, many inputs/outputs are pre-assigned to a function. the manual shows them.
Al.
Albert E.
