586,065 active members*
4,874 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > CMOS Battery Failure Hurco VM1
Results 1 to 13 of 13
    Mar 2015
    6
    Message on screen says CMOS Battery Failure, and won't boot past it.
    Before I call Hurco...
    I've searched the internet and this Forum but can't find anything specific like where the battery is or if there is one or what to do.
    Is there an actual Battery like a 2032 Coin battery that needs to be replaced?
    I can't find a Battery anywhere on any of the computer boards except something that looks like one on the left side of the computer cabinet but it's not.
    Or is this more involved like replacing something on one of the computer boards, Mother Board etc?
    Thanks in Advance for any help.
    Jun 2008
    1104
    Re: CMOS Battery Failure Hurco VM1
    It's on the board at the top. Pull it out and look for a small black block near the left end by the edge connector.
    Mar 2015
    6
    Quote Originally Posted by bloke View Post
    Is this it ?
    It was held in with a plastic tie wrap and just unplugs with lots of legs on each side.
    Couldn't find any info on it though by using the numbers.
    Update, Many Thanks for the info :cheers:
    I found an old post replied to you and found this DS12887
    Mar 2015
    6
    Ok one more thing, anyone know where to get this part in the USA ?
    Waiting to hear back from Hurco but the cross reference part # is DS12887 or DS12887A
    All the places I can get one are shipping from China and delivery is 4 weeks
    Jun 2008
    1104
    Ebay? There are loads of UK sellers with them so I'd assume there would be a bunch of US ones.
    Mar 2015
    6
    Thanks again, :cheers: I refined my EBay search and found a place in NJ ...
    Seller is.. plccenter
    Jun 2008
    1104
    Excellent!
    Jul 2015
    Hello
    When you change this part, is it now works? I mean, has it a normal BIOS installed in the chip or must be programming for BIOS?
    Nov 2017
    12
    I need to know that too. Do you need to change settings or programming?
    Feb 2016
    17
    Hi! I have the same problem, I've changed the CMOS battery (RTC) by the component M48T86PC1, the battery alarm disappear, but the "CMOS checksum error", not. I've tried to change the BIOS settings but when I reset the PC the Bios setting didn't change.
    Any idea to know how change the BIOS settings?
    Please help me.
    Jul 2006
    10
    Quote Originally Posted by antoniomasat View Post
    Please help me.
    Hey I'm having the same "CMOS checksum error" after changing out the M48T86PC1. I'm also not able to change the bios settings. Were you able to figure anything out? Thanks, Doug
    Mar 2015
    6
    Please help me.
    Sorry for not seeing this thread from back in 2017
    Quote Originally Posted by eaglegage View Post
    Well, here's the odd thing, I installed the CMOS chip and had to hook up a Key board to the Machine but never needed to change the BIOS
    Initially, I called Hurco Tech support and talked with Steve Artz.
    Hurco Tech. Support
    317-298-2635 Office Phone
    317-298-2621 Office Fax
    [email protected]
    He told me what to do with the key board with a round Cylinder connection on the end of the wire coming off the keyboard.
    And he also said to reset the Bios, BUT, I didn't need to do that for some reason after all was said and done.
    Here's what I did:
    I first tried it with an Adapter on a keyboard with a USB connector wire but that did not work... no communication to machine.
    So I had to find/use an older keyboard with a OEM round Cylinder connection on the end of the wire coming off the keyboard.
    Plugged in the keyboard and entered standard CMOS setup and Set Time and Date.
    Then went to change all the Primary Master etc etc . Type and Modes per Steve's instructions.
    The Type and Mode for all of them were set to AUTO and I could select/highlight them, but could not change them.
    Also could not select the heads, Cylinders or sectors etc ..
    So figured I'd at least save the Time and Date and exit.
    Machine then booted up fine.
    I then Calibrated XYZ and tool changer, ran a machine warm up and random tool changes, and then shut the machine down.
    Started it back up and it seemed to take longer than usual to boot, but since then everything has been good.
    I suggest to either call or email Steve if you guys have any problems getting it working again.
    Good Luck.
    Mar 2024
    Currently i have a hurco hawk 5ssm that has a cmos check sum error.
    Reaching out for any help i can get to get this rest.
    On the main screen its asking for F1 to be pressed which on the monitor doesn't do anything.
    I have a Ps2 keyboard but no adaptor yet for the db9 serial port on the electrical cabinet
    The computer boots with 2 beeps does anyone have experience with this that could help
  1. CMOS Battery Low after RTC Change
    By blender in forum HURCO
    Last Post: 08-12-2014, 03:37 PM
  2. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  3. CMOS Battery failure, Tree/ZPS VMC 760
    By pa2262 in forum Tree
    Last Post: 03-18-2013, 07:13 PM
  4. CMOS Battery
    By Holzwurm56 in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2012, 04:37 PM
  5. CMOS battery
    By APinSoFla in forum Milltronics
    Last Post: 02-15-2010, 04:25 PM
