586,033 active members*
3,598 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > I want to upgrade my K40 laser cutter controller!
Results 1 to 17 of 17
    Oct 2006
    65
    I've put a lot of work into this machine but the controller and software are just crap. It would stop engraving in the middle of work for no good reason and what's going on with MOSHI DRAW - I could not figure out how to use this crappy software!
    I want something that will work as should and will enable usage of normal software.
    I've seen several options on eBay:
    New DSP CO2 Laser Cutter ENGRAVER Machine LCD Motion Controller System PH3 | eBay
    CO2 Laser Engraving Cutter DSP Motion Control System PH3 0 | eBay
    Any suggestions from someone who has experience with any of these or similar?
    Jan 2010
    53
    I yanked my moshidraw board a week after I started using it. Took me 3 tries to find a board I liked. Arduino mega 2560 + ramps 1.4 board. I use inkscape 0.91 for generating my code using turnkeylaser extension. I upload the code using interface. And I use the turnkey recommended marlin firmware for the arduino. The MKS board is an arduino and ramps 1.4 together with some extra channels. I use an air assist nozzle with a select comfort bed air pump I modded. It's switched on by the ramps board. I do cuts of 1/4" plywood, engrave granite, so vector and raster using this setup.
    Look for my post earlier this week on software, I uploaded my modded turnkey inkscape extension.
    I had a engraving job running on a 85mm x 150mm granite sewing weight, it's a 8 hour job... yes the 40w is not powerful enough, but it'll get the job done eventually.
    All told I have maybe $100.00 in my upgrade.
    Oct 2006
    65
    Re: I want to upgrade my K40 laser cutter controller!
    Quote Originally Posted by Cromaglious View Post
    So you are using something similar to this one?
    MKS BASEV1 2 3D Printer Controller Board for RAMPS1 4 Arduino 2560 Remix Board | eBay
    And, in addition, it will require two of these?
    Geeetech Stepper Driver A4988 with Heatsink Sticker for Ramps Prusa i3 GT2560 | eBay
    Relay board:
    1 2 4 8 Channel 5V Relay Module Board for Arduino Pic AVR MCU DSP Arm | eBay
    This is in case I'm only running the X,Y stepper motors and nothing else.
    What else?
    Jan 2010
    53
    Quote Originally Posted by slow_rider View Post
    What else?
    Yeppers, you also need a 12 supply for the leds in side the lid and power to trip relays, I had a 9 outlet relay controlled strip (American Dj supply - left over from DJ days) ONLY USING 3 RELAYS AND THE ALWAYS ON outlet for the k40 itself. I'll post pictures tomorrow. Get an extra 50k ohm 50w resister (laser ballast) I'll get link tomorrow to you, cutting grid, removed the stock air horn for exhaust fan, added LCD 64x128 graphic. Gives you control at laser. That about it.
    Robi
    Oct 2006
    65
    I would highly appreciate it!!!
    Apr 2003
    540
    There is a google K40 group that you'll find a lot of info about these lasers and controller upgrades. Folks seem to prefer the new smoothie boards because of the memory and processor speed and you can get reasonably priced China clones now. With them folks are both engraving and cutting with success.
    Other than that a DSP controller is great, but they are pricey. They are available at light object with software and info.
    Jan 2010
    53
    Here's the pictures...Attachment 321404
    The RAMPS 1.4 and Arduino Mega 2560
    Attachment 321406
    The MKS board which is going into the other K40
    Attachment 321408
    My stock K40 still with moshidraw with the missing ballast resistor I used in the modded one to replace the bad on.
    Attachment 321410
    and the ballast resistors I got 60K 100W which seem to have a high enough voltage rating.
    here's a 50K 100W 50K Ohm Screw Tap Mounted Aluminum Housed Wirewound Resistors 2 Pcs | eBay
    $10
    Attachment 321412
    I haven't made a z stage for my cutter yet.. just using spacers to get the right Z height.
    and my 12v white LED's on the lid.
    Attachment 321414
    Robi
    Jan 2010
    53
    I was looking at the smoothie as well... Almost pulled the trigger and got it. My setup to upgrade the K40 was less than a price of a smoothie.
    Arduino + ramps 1.4 or MKS, Graphic LCD + SD reader + buzzer + encoder/switch, grid, hose. Then the free stuff I had laying around: air assist pump, thing-i-verse nozzle, DJ relay outlets, 12v supply, LED's were leftovers from something else.
    Robi
    Oct 2006
    65
    Thank you very much for the pics!
    I do have one question though - how come my laser cutter does not have a huge resistor like that (I guess that is for current limiting?)
    On a side note. I have a board that is connected to a water flow meter. If the water stops circulating it starts buzzing and can also send back a logic signal to indicate an error. Is that something that people might be interested seeing supported by software?
    Jan 2010
    53
    Water flow is supported in the software, I just don't have the flow sensor on this machine. and between this post and my last post I cracked the first mirror off the tub. so now my laser is down until I can either switch mirrors off the unconverted one and order new ones, which will be wednesday (the 1st -- PAYDAY!) The ballast resistor depends on the LASER PS and the maker... the stock one is a huge clay wire wound resister
    Attached Thumbnails Attached Thumbnails 20160526_105931.jpg   20160526_105931.jpg
    Robi
    Apr 2003
    540
    They were hard to find for a while and double the price of a Arduino/Ramps setup. Better prices and availability now and it's a faster, more powerful and is well supported (some other controller options are no longer getting support/updates for the laser cutters). Now that the ebay clones are out there it's an even cheaper option. I don't personally have a smoothie in mine now, but when/if I upgrade I'll likely go that route.
    Jan 2010
    53
    I saw one on ebay for $57, it's gonna have to wait a bit. just spent $30 on mirrors, couldn't tell what size without tearing things apart.. So I got 20mm and 25mm. Now I have to figure out how to clean the emitter on the laser tube.
    Robi
    Jan 2010
    53
    I finally got a MKS SBase, and I had it running in a K40... I really suggest using a real smoothieboard. I'm saving up for mine now.
    Robi
    Jun 2015
    What issues did you have with the MKS SBase?
    Mar 2015
    59
    Hi guys. I just received my k40 and sure backup everything you say about the software. I haven't had it long enough to judge much about operational problems, but the flow is horribly convoluted. I'm ordering a MKS SBase ASAP. After 3 years of building 3d printers and progressively larger CNC routers, I think I can handle that part, but don't know if there's anything I need to be aware of with controlling the tube itself and what software to check out.
    I'm really not trying to hijack the thread guys, just tying to follow what you are talking about.
    Thanks, Larry
    Jan 2007
    Cohesion 3d has a fix for that...
    Sep 2018
    83
    Check out Lightburn - it's a fantastic software package written by a guy that specifically supports Chiense laser cutter types, including the K40. I promise you it will make the world of difference to your overall experience using a Chinese laser.
  1. Replacement controller for K40 laser cutter
    By Downunder35m in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2016, 05:46 AM
  2. Laser Cutter Upgrade
    By jazz352060 in forum Australia, New Zealand Club House
    Last Post: 08-05-2015, 03:36 AM
  3. Some questions regarding my new K40 laser cutter w/a Moshi controller
    By reilleyem in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2015, 09:12 PM
  4. New DIY exhaust for K40 CO2 laser cutter from China - Huge upgrade for $6
    By slow_rider in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2015, 12:36 PM
  5. Motors and controller for upgrade a esab picorex oxy gas cutter table
    By ignacio_an in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-09-2014, 08:48 AM
