586,121 active members*
3,643 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Affordable 110V DC PWM motor controller?
Results 1 to 2 of 2
    Apr 2013
    162
    I have a GS Electric B4PCM-072T 110V DC permanent magnet treadmill motor. 5100 RPM, claims to be 1.5 HP. Already have it mounted on a lathe.
    What's available in PWM controllers today, at an affordable price? Close to $100 as I can get. Preferably with both a pot input for manual control, another input suitable for CNC control, and connections for a switch to change between them.
    Even better would be to have it 'fail off' if no input controls or the input switch is connected.
    Those cheap sub-$20 ones 'fail-ON' if there's nothing connected to the 3 pin header for control select, and the fuse turns into a flashbulb since the controller sends full power to the motor output. I tried one of those, got it all working, added a fuse holder by soldering wired to the ends of a blown fuse. Then when I closed up the box and turned on the power, popped the slow blow fuse. Opened it up, checked everything, continuity, connections all good. But all it'll do is act as though nothing is connected to the input select header. Probably popped some component on it.
    Dec 2003
    24221
    Re: Affordable 110V DC PWM motor controller?
    Look for one of the KB/Baldor PWM type controllers on ebay, many are SCR type which are not so good as the PWM ver.
    Check the KB site to confirm the type by part No.
    Al.
    Albert E.
  1. Weiss 1100 Watt Motor 110V RPM???
    By photomankc in forum Benchtop Machines
    Last Post: 10-04-2017, 12:58 AM
  2. Change Motor voltage from 110v to 220v
    By J.A.C in forum Benchtop Machines
    Last Post: 12-29-2013, 12:22 AM
  3. Replies: 20
    Last Post: 12-05-2013, 05:54 AM
  4. 110v single phase bridgeport motor swap
    By stanglou in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2011, 12:41 AM
  5. Spindle motor and VFD for 110v
    By shadowless in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 04:51 AM
