586,102 active members*
2,394 visitors online*
    Sep 2012
    MAXPRO200 using H35 plus N2
    Jim, I am thinking about to cut with MAXPRO200 using H35 plus N2 instead N2/N2 according manufacturer manual onformation. Do you know if anybody has tested it yet ? I am not sure the consumables will give to me good results for stainless steel.
    thanks
    Jan 2008
    2247
    Re: MAXPRO200 using H35 plus N2
    Bestmark,
    The MaxPro200 is not designed for use with H35 (which is 35% hydrogen, 65% argon). This gas is considered explosive, and would need a different style gas delivery system, as well as different consumable designs to be safe. I do not recommend using any gases other than the ones listed in the operators manual cut charts.
    Best regards, Jim Colt
    Sep 2012
    Thanks Jim
  1. Replies: 0
    Last Post: 02-14-2014, 11:32 PM
