586,076 active members*
4,037 visitors online*
    Nov 2015
    31
    Looking for a bit for phenolic
    I have been cutting .0625 canvas reinforced phenolic sheet, decent volume of parts that have a number of 1/8th inch holes that need to be drilled and then profiled out of the sheets. Since the relationship between the holes and the edges of the pieces isn't particularly critical (.025-.030 would be all but unnoticeable) I have been stacking them up 12 high and drilling all the holes and then using some aluminum plates and bolts through the holes to hold 8 at a time to inserts in my spoil board for the profile operations. This works pretty well, I just can't seem to find a bit that my machine can use make use of that will give me a decent top edge along the cuts. I have been using a 46092 Solid Carbide Spiral 3/16 Dia x 5/8 x 1/4 Shank x 2-1/2 Inch Long Composite, Fiberglass & Phenolic Cutting ZrN Coated Up-Cut Router Bit since one of the parts I can only fit 3/16 between them without losing a ton of material to waste.
    Today I tried a 48052-E High Performance Solid Carbide Fiberglass and Composite Cutting 1/4 Dia x 1 x 1/4 Shank AlTiN Coated End Mill Router Bit after reading that they are supposed to produce a nice edge finish top and bottom, but I don't think my machine can push this thing fast enough. I am limited to 16000 rpm at the low end, and about 150 ipm with even .134 doc before I start having problems losing steps. At these speeds the bit produces a nasty high pitch squeal that I assume is from chatter that would only go away if I brought the feed down to like 10-15 ipm. It also produced a terrible edge, even worse than the upcut on most of the pieces. I am having trouble figuring out how to calculate a good starting feed rate for the bit as I don't know how many flutes to use in the calculation. I have posted to Amana's support forums but haven't heard anything back yet, and haven't been able to get away during the business day to call them, but I am pretty sure my problem is not being able to drive the bit fast enough.
    Does anyone have any suggestions on another type of bit that might work better for me, I have thought about grabbing the 1/4 inch down cut version of the 46092 even though I couldn't use it on all the parts, it would save me a good bit of sanding time if it worked better. I just don't really see how it wouldn't just move the bad edge to the bottom instead of the top.
    Nov 2014
    28
    Re: Looking for a bit for phenolic
    Quote Originally Posted by Wildkard View Post
    What's your fastest feed rate your machine can handle straight line and what the fastest it can go around a radius without leaving steps? If you haven't figured it out yet I can help you with speeds and feeds...
    Sent from my SM-G930T using Tapatalk
  1. Machining Phenolic
    By ranchak in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2016, 07:41 PM
  2. Machining G10 & Canvas CE Phenolic?
    By Concepts_Design in forum Tormach Personal CNC Mill
    Last Post: 08-15-2015, 11:18 PM
  3. Phenolic advice
    By DrStein99 in forum Composites, Exotic Metals etc
    Last Post: 04-08-2012, 02:49 AM
  4. 300-600 Phenolic Bushings
    By CX750 in forum Employment Opportunity
    Last Post: 12-08-2010, 04:21 AM
