586,655 active members*
2,629 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Wrong file ext.
    May 2016
    Wrong file ext.
    I'm working on a Balestrini 9 axis profiler, today I needed to insert a speed change into the drawing ut when I saved it, it save with .anc extension file, when it generaly save with .xpi files.
    I tried to remove the speed change modification, and it save with the .xpi
    Then I remade the speed change, and again it saved in .anc, but the software that run the CNC can only load .xpi files
    It was not the first time I make a speed change but its the first time it save like this
    Thank you for the answer,
    Hendrix Brière
    Apr 2015
    327
    Re: Wrong file ext.
    Hello,
    hard to understand what you mean. Problem is with extension or what?
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. Replies: 6
    Last Post: 01-09-2014, 12:05 AM
  2. file saved wrong version
    By jrmach in forum BobCad-Cam
    Last Post: 09-05-2012, 11:55 AM
  3. Replies: 11
    Last Post: 04-25-2012, 04:39 PM
  4. Can someone look at this file, and tell me whats wrong?
    By blakemachine in forum Mastercam
    Last Post: 07-30-2009, 05:35 AM
  5. "wrong program data" when file transfer????
    By spock in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2008, 11:59 PM
