587,047 active members*
3,289 visitors online*
    Jun 2015
    4156
    waterjet cutting speed fluctuations
    hello this thread is about possibility of improving cutting speed on a waterjet
    material olc45, 32mm height; shape to cut and afferent machine program are attached
    shape is simple, few geometrical entities ( 12segments + 10 arches ), while program is long ~800lines only for movement
    consider a cutting value 60 [mm/min ] : for a segment, machine starts at 5 mm/min, and raises until the middle of the segment, and after it decreases again to take the sharp angle with low speed; speed is changed at discret segments of 0.1length, and so maximum cutting speed is not achieved every time
    is like acc / decelaration paliers are way too long ...
    - movement begins near material, not on it's surface; if material is pierced at 60mm/min, why not start with 100% speed ?
    - how long should be a deceleration palier, before taking a straight corner ? i was thinking that 5..7 mm should be enough, so just to go full speed till there; reduce speed with 5 mm before the corner, and take it
    - for arches, depending on their radius, i guess i must consider 30 .. 40 ..60 ..80% of full speed ?
    i am not sure, but i believe that i can drasticcally improve speed please, are there some tricks to handle this ?
    for this shape:
    .... for 15mm/min speed, overall time was 30minutes
    .... for 30mm/min speed, overall time was 18minutes
    .... for 60mm/min speed, overall time was 15minutes
    time is almost identical for 30 or 60mm/min ... kindly !
    Attached Files Attached Files
    Jun 2015
    4156
    Re: waterjet cutting speed fluctuations
    hello again, as shown in images from post1, there are cutted 4 geometrical groups :
    - 1st group - 3 lines
    - 2nd groups - lines and arches
    - 3rd group - 1st one a bit scaled & mirrored
    - 4h group - 2nd one mirrored
    So i take into consideration only group 1 and 2
    This post is about group 1 ( image 01 ), simple as it is, it contains 3 lines ...
    I have extracted positions and feed from program attached at post 1. I have created some charts, and paste them inside a doc file attached. If you wish to take a look, please consider a view as shown in image 02, so to have a general perspective
    Is easy to locate on charts position where one segment ends and another begins ...
    Charts :
    1) feed - feed variations among all 3 segments
    2) df - changes between 2 consecutive feeds : Feed_current_position-F_last_position
    3 & 4) dx & dy - changes on X ( Y ) axis between 2 consecutive positions
    5) chart 1 again
    6 , 7 , 8 ) absolute values for charts 2 , 3 & 4
    9) dl - segment length between 2 consecutive positions; dl^2 = dx^2 + dy^2
    [ observations ]
    a) since material has been pierced, than feed can be accelerated and decelerated faster, as shown in image 03; maximum value may be equal to "program maxim" or close to it; i am not sure, but feed = "program maxim" may not work, because on chart this feed is mantained for a short period of time, and thus, delay helps to pierce material; speeding with feed = "program maxim" may not pierce, since there is no delay arround each position, so 80..90% may work
    b) every chart has a sharp design, as shown in image 04 ... i don't know why ... maybe this behaviour is not present on other machines / water jet instalations ... this aspect can be improved from code
    c) as seen in "df" charts, feed always changes with constant value, except for local oscilations; cause most likely similar to conclusion b) ... machine works smooth almost all the time, and suddenly something shakes; biggest feed oscilations, as shown in image 05, are because cutting direction is being changed; direction changing is done with low feed, but machine accelerates / decelerates to this values aggressive; changes should be smooth, and so to cause a delay, so waterjet will stay near this point for longer time, allowing better piercing
    d) as seen in "dl" chart, cutting start with small segments ~0.1, and reaches also segments close to 0.9 length; this is because of the long acc / decc paliers
    [ conclusions ]
    1) speed changing palier ( acceleration / decelaration ) should be shortened, i guess from software interface
    2) is necesary to :
    2.1) ......... improve cornering
    2.2) ......... reduce sharp design, described at observation b)
    1 >>> less process duration
    2.1 >>> same effect as 1) but with less impact
    2.2 >>> smooth behaviour
    - water jet machine is not mine, otherwise i would experiment with it ... i tried to rough some metal parts, but jet duration was too big compared to mill ; i don't know how much time i can reduce, but i am sure i can ... i have discused this conclusions with jet operator, and he discoverd an interface from where may be possible to change acc / decc paliers
    - sometimes is good if things work
    - much better when things work much faster; this type of improvements are time consuming ... kindly !
  1. voltage fluctuations - what is best for digital drives
    By nicubila in forum CNC Machine Related Electronics
    Last Post: 11-03-2013, 04:21 PM
  2. Waterjet cutting machine promotion of JETE WATERJET
    By livemott in forum News Announcements
    Last Post: 09-25-2011, 03:25 PM
  3. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  4. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
  5. Cutting speed locked to Z torch height control speed
    By Beefy in forum Mach Plasma / Laser
    Last Post: 02-15-2010, 12:14 AM
