Re: Latest Design CRP PRO4896 Build log Awesomeness!!
Originally Posted by
RCaffin
I would not call Vista an 'operating system'. Unmitigated disatster might be more appropriate.
WXP SP3 is the classic OS for Mach3, but if you are NOT using the parallel port then W7 is fine.
If you are using the PP, then stay with WXP SP3.
Cheers
Roger
WinXP is one OS that MS got spot on! As I use the PP I run it on all my control machines and never have an issue of any kind. I am running a cut down version though that has almost everything stripped out, but it's absolutely rock solid.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
