586,545 active members*
3,138 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mach3, Mach 4 or Linux CNC for G0704
Page 6 of 8 45678
Results 101 to 120 of 152
  1. #101
    Jun 2010
    4256
    Re: Mach3, Mach 4 or Linux CNC for G0704
    some of my programs have hundreds of segments per inch.
    That would be typical wood router territory? 5 million data points from a 3D map? I am not familiar with that class of program. I'll pass.
    Instead I tend to go for engineering designs, where a 50 mm circle can be machined with one or two lines of code.
    This does raise a point about lines/second. My CNC can only machine a few lines/second, as each line is quite long. It is possible that the PC could limit the machine speed IF it went through the PP. I use an ESS, which can turn lines/second into lines/millisecond. Having an external engine for the pulsing is so very helpful for speed. Mach, UCCNC and LinuxCNC (and others too I imagine) can all do this today. Here's to FPGAs!
    Cheers
    Roger
  2. #102
    Jun 2007
    3891
    Quote Originally Posted by RCaffin View Post
    no, no it cant. the only thing that can do that is processing power and clever trajectory planner. pulses per second only determine how fast your motor can go. fpga dont do squat (when used this way anyway). the fastest contouring controls on the market right now can process about 2000 blocks per second. the typical control you might find on a new lower end vmc is around 50-200 blocks per second. theres no definitive numbers for mach or linuxcnc as the hardware is variable, but they should land somewhere in between.
    on a metal milling machine, your bottleneck is usually mechanical. you can only cut metal so fast with the small tools used in these high definition programs. in wood, the bottleneck is block processing because you can pretty much cut as fast as the mechanical limits of the machine allow. a high definition 3d contouring program will hit the limits of most controls easily.
  3. #103
    Sep 2009
    1856
    keep it to hobby, jerk control with CV is very interesting to set up, but having jerk control does make cornering a lot better, it's a differences you can hear more than see.
    the other way is to get a good cam program that has corner rounding compensation, that makes Mach3 a lot better to use as you can set the speed to a speed you know the machine will be fine going around a corner. doing 3D cuts it makes it take a bit more time but the outcome is a lot better and less clean up work.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  4. #104
    Jun 2015
    943
    There is no CAM program which will fix you the no deviation control and broken CV planner problem.
  5. #105
    Sep 2009
    1856
    did I say fix NO, makes it BETTER batman will win
    [SIGPIC][/SIGPIC]
  6. #106
    Jun 2015
    943
    The Mach3 trajectory planner is a black box so you can only assume it will make it better, in my experiences in 3D works using different CAM settings or milling strategies will mostly make no difference. It gives no solution or workaround.
  7. #107
    Sep 2009
    1856
    I have used it and done it and it works well else why would I say it, if you drive mach3 slowly it goes around corners quite well, if you go fast it is crap at it so if you slow down then go around the corner then speed back up it makes it better ai.
    all you have to do is find the speed that it corners ok, then you set that speed as the speed to use then it is better. and no it does not fix it how can it it lessons the problem with corners. I know how mach 3 trajectory planner works the man who did it explained it and what is wrong with it.
    so that gives you what to do to minimize the problem
    quite simple ai so spider man will get his arise kicked by captain america
    [SIGPIC][/SIGPIC]
  8. #108
    Jun 2010
    4256
    There are several sorts of 3D machining. My interest is in the engineering style. Others may differ.
    Attachment 321988
    All these parts have been made by Mach3 for handling the connection to a propane/butane canister. You need some fairly high precision to avoid leaks. Leaks, near a flame, are embarrassing.
    Attachment 321990
    These parts are machined on all 6 sides and are also bored out in a complex manner, also by Mach3. Again, some precision is needed as they too are handling propane.
    This is very different from making table legs or carving faces on a piece of wood. Yes, this engineering stuff can be done slower - in fact it needs to be done slower. Accuracy is not in question, but close tolerances and precision are essential. Mind you, I would imagine that UCCNC and LinuxCNC could do just as well.
    Horses for courses?
    Cheers
    Roger
  9. #109
    Aug 2014
    889
    I guess I'll never know. When installed it throws out unhandled exception and does'nt start.
    Right o way, that turns me off. In this day and age a demo crashes. Win 7 64 bit. Come on................
  10. #110
    Jun 2015
    943
    I'm running UCCNC around 6 months now on 2 machines, never threw an exception, never missed a beat, can't tell the same about Mach3, used it for a longer time.
  11. #111
    You have an issue with your PC.
    It's run for me on XP, 7, 8.1 and 10, with no problems.
  12. #112
    Aug 2014
    889
    Attachment 321992
    Details....................
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    at OpenTK.Platform.Windows.Functions.DescribePixelFor mat(IntPtr deviceContext, Int32 pixel, Int32 pfdSize, PixelFormatDescriptor& pixelFormat)
    at OpenTK.Platform.Windows.WinGraphicsMode.ChoosePixe lFormatPFD(IntPtr device, GraphicsMode mode, AccelerationType requested_acceleration_type)
    at OpenTK.Platform.Windows.WinGraphicsMode.SelectGrap hicsMode(ColorFormat color, Int32 depth, Int32 stencil, Int32 samples, ColorFormat accum, Int32 buffers, Boolean stereo)
    at OpenTK.Platform.Windows.WinGLContext.SetGraphicsMo dePFD(WinGraphicsMode mode_selector, GraphicsMode mode, WinWindowInfo window)
    at OpenTK.Platform.Windows.WinGLContext.TemporaryCont ext..ctor(INativeWindow native)
    at OpenTK.Platform.Windows.WinGLContext..ctor(Graphic sMode format, WinWindowInfo window, IGraphicsContext sharedContext, Int32 major, Int32 minor, GraphicsContextFlags flags)
    at OpenTK.Platform.Windows.WinFactory.CreateGLContext (GraphicsMode mode, IWindowInfo window, IGraphicsContext shareContext, Boolean directRendering, Int32 major, Int32 minor, GraphicsContextFlags flags)
    at OpenTK.Graphics.GraphicsContext..ctor(GraphicsMode mode, IWindowInfo window, Int32 major, Int32 minor, GraphicsContextFlags flags)
    at OpenTK.WinGLControl.CreateContext(Int32 major, Int32 minor, GraphicsContextFlags flags)
    at OpenTK.GLControl.OnHandleCreated(EventArgs e)
    at System.Windows.Forms.Control.WmCreate(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.UserControl.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    UCCNC
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/UCCNC/UCCNC.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1664.6217
    CodeBase: file:///C:/UCCNC/OpenTK.DLL
    癠䣿ᅯ鞎䃃�뿛
    Assembly Version: 0.0.65535.65535
    OpenTK.GLControl
    CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  13. #113
    Aug 2014
    889
    Always something.........
  14. #114
    Try updating your video card drivers. Looks like a graphics error.
  15. #115
    Jun 2007
    3891
    does seem to be yes.
  16. #116
    Jun 2014
    777
    A lot of it may come down to motion control, I was recently donated a 6040 and have put it the task of cutting foam tool control inserts. I have attached an image of two version, one cut by Mach 3 and another using same bob only plugging in a uc400 and using uccnc. The only difrence in toolpath is that radius are turned off in pp to support uccnc. I set the cv angle and distances the same in both Mach 3 and uccnc and the motor tuning the same. The rough version was Mach 3.
  17. #117
    Jun 2014
    777
    Quote Originally Posted by Jon.N.CNC View Post
    For some reason I cant attach file on phone without replying with quote,
    Images attached:
  18. #118
    Jun 2010
    4256
    Interesting.
    The left hand one looks as though it had CV off, but I know so little about foam cutting.
    Were the total times and speeds the same?
    Cheers
    Roger
  19. #119
    Jun 2014
    777
    Interesting.
    Cheers
    Roger
    Nope settings were identical. Both took just over an hour, I didn't log the times stupidly but if there was any difrence it could have only been a minute or two. The motion control and tragectory planning of uc hardware and software smoothed motion considerably and i believe that is what can been seen.
    Cutting foam is a pain, especially if cutting pockets as close together as I am in these. Have to treat it delicately and you have to employ both climb to rough and not clog the bit, and conventional to get a finish (use adaptive clearing if you get issues with standard pocketing pulling in foam). You can spot an error in the uccnc version on first stubby spanner where foam pulled into the bit even though same speed this didn't happen on rough version. So kind of things you have to deal with. Solution is go slightly slower.
  20. #120
    Jun 2007
    3891
    yeah theres something going on there thats not mach3 "accuracy". any so called path deviation in mach would if anything result in a smoother (but incorrect) shape. youve got something else going on there.
    you are aware i assume that when you first instal mach, often times cv is explicitly disabled in the xml and isnt turned on by g64 in the program or by any setting in the setup page. theres one parameter that has to be changed (i cant remember which offhand, ive written about it on here before.
    though even with cv off, thats bizarre, unless the machine is quite floppy with high acceleration and its just shaking to death.
Page 6 of 8 45678
  1. Replies: 2
    Last Post: 05-29-2013, 07:36 PM
  2. Mach 3 vs Linux Cnc
    By tamartin in forum Benchtop Machines
    Last Post: 01-29-2013, 02:23 AM
  3. Linux/EMC VS Mach3 Where to Start
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 01-29-2008, 03:46 PM
  4. Anyone try mach3 with linux/wine
    By timmyb199 in forum Machines running Mach Software
    Last Post: 10-23-2006, 07:32 AM
