586,036 active members*
3,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Looking for a small facing tool (fly cutter / face mill / indexable end mill)
Results 1 to 15 of 15
    May 2016
    16
    The parts I make (for folding knives) generally fit in a 2x6" envelope, so they're relatively small. I've been facing them using some 1/2" end mills, but it feels wasteful to only use the tip of the flutes, and it's slow.
    So, I'm looking for a small facing tool to suit my needs. I'm using a PCNC 1100, so it would either need to be TTS compliant or converted. Is the Tormach Superfly my best option, or are there cheaper alternatives?
    Jun 2014
    1780
    Re: Looking for a small facing tool (fly cutter / face mill / indexable end mill)
    I use a Shars 2 1/2" face mill, it was less than 100 dollars and has replaceable carbide inserts.
    For my smaller cutters I use a cutter grinder to sharpen the ends and flutes, they are kind of expensive so I wouldnt recommend buying one, I had this from my previous business, sure comes in handy these days.
    mike sr
    Jun 2006
    3063
    Quote Originally Posted by polar8 View Post
    Can you use the 38 mm face mills from Tormach?
    Face Mills
    Those have the TTS collar built in*. If smaller cutting diameters would work better, try one of their insert end mills would work:
    End Mills
    End Mills - Center Cut
    The former are available in diameters of 16, 21, or 25 mm but you'll also need TTS arbors.
    I've used both the face mill and smaller end mill with aluminum inserts and they do a really nice job with close to a mirror finish. I've yet to try either with inserts for general purpose steel.
    [*on edit - the face mill also needs a TTS arbor]
    Aug 2009
    610
    The SuperFly does a good job and is pretty quick in taking a 2" swath. I'm assuming that you are working in Titanium. If so you need to get a coated insert (not the one for aluminum that is sold) and flood coolant is a must. A number of years ago I decided to fly cut titanium for the first time just to take 10 thou off the top of a piece of Grade 5 stock. Let's just put it this way I thought it was the 4th of July in my shop! If I had to do it all over again I would have purchased a dedicated 3/4" shank 2" face mill and DIY'd a TTS holder for it vs. the superfly.
    Aug 2015
    368
    I use the super fly, it's great on everything except titanium. How are you finishing the material, what material, after you face it?
    Sent from my SM-G900V using Tapatalk
    Aug 2015
    368
    Hers a video of the SuperFly on grade 5
    TMODCUSTOMS CNC TITANIUM: https://youtu.be/iC0-1Em3FMc
    Mar 2009
    1863
    I use a 1 inch Shear Hog on my PCNC 1100. AT 3500 RPM AND 40 IPM I get an unbelievable finish on aluminum. The Shear Hog only works on aluminum.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Aug 2009
    610
    Yeah I had the same "glowing" experience until I learned the correct speeds/feeds and coolant flow necessary. Having a coated insert made a huge difference too.
    Aug 2015
    58
    Quote Originally Posted by pickled View Post
    If you still have it do you mind sharing the feeds and speeds that worked for you in titanium?
    May 2012
    17
    I use a K tool mm-500. A .5 inch, 3 insert cutter.
    K-Tool, Inc.- Indexable Carbide Mini Mills
    May 2016
    16
    I'd be interested to hear about your feeds/speeds too. I just picked up a superfly myself.
    Aug 2015
    368
    I run mine aroubd 3000 to 3300rpm, I usually jog it manually so ipm depends on depth for be, I prolly take a lot bigger cut tan most tho, I'd be interested in hearing f/s for it as well, in aluminum and titanium, if that's what your saying, ..
    Aug 2009
    610
    My titanium fly cutting is done on my PCNC 770 in low gear at 1250 RPM 2.3 IPM at up to a 45 thou DOC. The Superfly is set up for a 1.9" diameter cutting circle. I use TiCN coated carbide inserts in the superfly and copious amounts of flood. I bought a ton of the inserts pretty cheap during an online auction. Will post a picture of the surface finish that I get later. I ALWAYS CLEAN the mill and chip pan before I fly cut, or spindle turn titanium! It will easily burn big holes in your way covers too so be careful! Have a great weekend guys.....:cheers:
    Aug 2015
    368
    That's impressive, thanks!
    Aug 2009
    610
    Quote Originally Posted by tbev View Post
    Yes it is OOOPS!!! That should read 2.3
    IPM NOT 3.2. Sorry about that folks!! Proceed with caution YMMV.
  1. Looking for small face mill
    By kiwisoundguy in forum Want To Buy...Need help!
    Last Post: 09-20-2011, 02:57 PM
  2. indexable face mill setup
    By fjbart70 in forum MetalWork Discussion
    Last Post: 04-20-2011, 11:39 PM
  3. Indexable Angle, Conical Mill & Web Prep Cutter
    By CDTooling in forum News Announcements
    Last Post: 08-22-2010, 10:29 PM
  4. How to choose a Facing Mill or Fly Cutter
    By TimGS in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2009, 04:23 AM
  5. Indexable face mill ?
    By Ken_Shea in forum MetalWork Discussion
    Last Post: 09-29-2004, 04:25 AM
