586,119 active members*
3,549 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse Rover - Error during Homing of Machine
Results 1 to 13 of 13
    Dear All,
    I have problem during Homing of Machine, Homing of Z-axis is fine, follow by X-axis then the problem occurred, machine stop.
    Already check and bypass the safety mats, didn't find any solution for the error.
    Error show - PLC 9010 > Cycle stop from RH safety area device
    PLC 9943 > if the machine remains in suspension, reset the safety mats by pressing one of the area selection buttons or the power button.
    Need help !
    Thank You.
    Jan 2017
    44
    Re: Biesse Rover - Error during Homing of Machine
    i have the same error .... does someone know the solution
    Does we can disable the safety mat ... (please i know what i am doing and people who just want to answer ....whoua ! you are crazy disabling the mat ... just don't answer ...)
    Any help grantly apreciate ...
    Aug 2005
    128
    Find the input in the schematics, get the module number and check to see if it is true. (light for input is on), then remove the wire.
    Jan 2017
    44
    Thanks Bob ... does in the lectric plant we find a section talking about the safety mat ?
    Aug 2005
    128
    I dont know, its all in french so I may be missing it but I checked and couldnt find it.
    Its probably the mesh guards.... but they are jumped out on your machine.
    Aug 2005
    128
    Quote Originally Posted by bevins View Post
    input 58189 Violation of left working area. I think thats it. Check your module 10 on the machine chassis.
    Sep 2011
    41
    How have you disabled the mats?
    If you have bridged the cables going into the mats (and you have done that correctly) you may have a faulty mat control module.
    Aug 2005
    128
    Quote Originally Posted by Miz View Post
    It was jumped and it is working on his machine now.
    Jan 2017
    44
    base on the electric plant was simple to jump the mat safety ...
    Jun 2018
    Someone can explain me how to make the bridge.
    My Machine (biesse rover C) is completely blocked.
    Error show - PLC 9009
    Thank you!
    im having the same issue with my machine rover C
    Jan 2020
    Hi Bob,
    Did you manage to get a fix for this issue? I am faced with the same problem, I am certain all my mats are working correctly though as we have tested them and watched the control modules etc. everything seems to be in working order??
    Please let me know how and if you managed to overcome this issue!
    Best Regards,
    Brad
    Sep 2020
    5
    Hi Brad,
    Did you solve the problem, I dont know what to do?
    Best regards,
    Alejandro
  1. Biesse Rover error- Present sensor lacking
    By dbattaglia in forum Biesse
    Last Post: 01-21-2020, 02:44 PM
  2. biesse rover b 4.40 ftk plc 432 error ybn.1.2.6.
    By cutewinuscream in forum Controller & Computer Solutions
    Last Post: 09-04-2019, 07:27 AM
  3. Biesse Rover A3 - PLC error
    By v3rbatim99 in forum CNC Machining Centers
    Last Post: 07-25-2019, 07:24 AM
  4. Replies: 1
    Last Post: 05-07-2017, 05:01 PM
