586,069 active members*
3,608 visitors online*
    Apr 2006
    93
    Cutting galvanized
    When plasma cutting galvanized steel, the edge of the cut will rust now right?
    What can be done to prevent this?
    Mar 2006
    759
    http://www.htpweld.com/products/accessories/a6.html
    prime-a-weld is great stuff.
    Home depot also sells a Zinc primer that works real good.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
  1. Hot Dipped Galvanized
    By MasterRusty in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2012, 10:38 PM
  2. Difference between galvanized pipe and DOM
    By ckrantz in forum Material Machining Solutions
    Last Post: 11-23-2006, 07:12 AM
  3. emt conduit, galvanized pipe or black pipe?
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-22-2006, 02:24 AM
  4. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
