Hi all - so I finally got my cnc put together (kickstarter CreationStation - quite the saga and I was lucky to receive one). Running linuxcnc - and after a few fits and false starts have managed to start making chips (yay!). I've been using Vectric VCarve Pro and one of their tutorials (a vcarved sign). For some reason while cutting with the vbit the router takes an unexpectedly deep z plunge and just start trying to keep cutting from that point (and I have to hit e-stop). I've double checked the collet and it's tight - bit isn't slipping. I quit and re-started linuxcnc but it did it again. Any thoughts, suggestions, or pointers you can share? I believe it was doing the same thing with the test code that the creator linked from his assembly instructions... cutting along fine then a sudden plunge.
If you don't think it's likely a linuxcnc issue, please suggest the appropriate forum & I'll repost this there.
thanks!
--B
