So I have the pretty common 2.2kw 24000 rpm water cooled spindle and HY VFD. I'm trying to get this to run using the smooth stepper and the c62 board from cnc4pc.
I have confirmed I get the analog signal at the VFD up to 10v depending on my spindle speed I set. I can verify on terminals that the relays on the c62 are working right by checking ohms on VFD terminals indicating open and closed. The relays are in the right sequence for cw and ccw. I used international mode on c62 and set parameters in drive for this mode.
I can't get the VFD to work!!! I can manually control it with the VFD controller, but nothing in Mach3.
I have the proper wires ran for for/Rev acm, dcm, and vi (0-10v)
My VFD just shows a flashing f000 or f400 (setting dependent) and won't start when pd001 is set to 1 or external control.
Now searching the world wide Web for hour and hours and hour...possibly days now, I have found a set of about 100 different instructions on settings so far nothing a success, but seems like most are for people controlling with VFD control and not pwm.
Anyone point me in a direction or had experience in this drive?
Sent from my SM-N910V using Tapatalk
