586,103 active members*
3,882 visitors online*
Results 1 to 7 of 7
    Jul 2012
    55
    Cam Tool trouble ZW3d
    Hello!
    I've bought ZW3D 3X machining a few days ago and I'm trying to learn myself the CAM part. We have a few Cnc routers for woodwork and want to use ZW3D for faster workflow.
    I'm having trouble understanding the tool library. When I make a library and ad a few tools with their size, RPM feedspeed and depth of cut etc you would think that these values will be used when assigning tools to cutting operations.
    For some reason the diameter is fine, when i make a 8 mm routerbit it stays 8 mm but the RPM and feedspeed is altered.
    How do I link feedspeed and RPM to a specific tool so that when I select the tool all the parameters are used for the cutting operation?
    Mar 2008
    683
    Re: Cam Tool trouble ZW3d
    Howdy,
    Here is a link at the ZW3D thread with this question answered. I don't know if you need to be a member but it could be worth it.
    Speeds & Feeds in ZW3D - CAD/CAM discussion forum
    Also it appears 2016 has a few issues. Make sure you get the new 2016SP service pack installed.
    I have used ZW (formerly VX) for years. It's very capable once you get use to all the odd way they do things. It has come a long way since the CHinese bought it. If it weren't for my client requirements I would use ZW exclusively
    Dec 2012
    28
    Hello Jacala, I'm Sean, channel manager of ZW3D. For your questions, please email our technical support team at [email protected], so our engineers can give you the solutions.
    May 2015
    1422
    ^^ When I was evaluating ZW3D as a potential CAD/CAM solution last year their tech support were extremely helpful. Definitely ask them for help with this kinda stuff.
    Sad to say I didn't go ahead - my Mac running Fusion didn't support the correct level of OpenGL needed by ZW3D so nothing worked and I wasn't prepared to get a new performant machine just for the CAD.
    Dec 2012
    28
    Hello, for OpenGL issue, here is solution to adjust the level, then you get the correct display like me when using MAC
    1st Step:
    C:\Users\"your PC name"\AppData\Roaming\ZW3D 2016 Eng (x64)
    2nd Step:
    Open file "_config"
    3rd Step:
    Find:
    # Display Level
    # 0=auto select, 1=OpenGL 1.5, 2=OpenGL 2.0, 3=OpenGL 3.0)
    Z3.DisplayLevel = 0
    and change "Z3.DisplayLevel = 0" to be "Z3.DisplayLevel = 2"
    May 2015
    1422
    I should have asked last year, rather than just throwing the baby out with the bathwater. I'm using another product at the moment - my client has loaned me a license for their choice of CAD/CAM. When this contract runs out though, I may have to get back in touch!
    Dec 2012
    28
    No problem, hope you can happy with ZW3D then Here is another option to adjust OpenGL:
    Go to the installation "shaders" file of ZW3D, the location is "C:\Program Files\ZWSOFT\ZW3D 2016 Eng (x64)\shaders"
    Copy the whole file "GL21" and save it as a new name "GL32" to replace the original one. Please backup the original "GL32" file in case you have some problems.
  1. Replies: 0
    Last Post: 06-21-2012, 04:05 AM
  2. Replies: 0
    Last Post: 05-24-2012, 02:41 AM
  3. Trouble with chattering tool
    By 8man in forum Benchtop Machines
    Last Post: 10-22-2007, 12:58 PM
  4. Trouble w/ air tool holder????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-16-2007, 12:34 AM
  5. Tool holder trouble
    By an0n in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2005, 04:43 PM
