586,061 active members*
4,529 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Can i load in Gcode(.tap) generated from other software to view simulation?
Results 1 to 8 of 8
    Oct 2007
    446
    Question Can i load in Gcode(.tap) generated from other software to view simulation?
    Can i load in Gcode files(.tap) generated from other software to view simulation in bobcad??
    Jun 2008
    1838
    Re: Can i load in Gcode(.tap) generated from other software to view simulation?
    Needs to an .nc format file, .tap is for Mach3.
    Oct 2007
    446
    i could just rename the extension?? So what is the process to load up and simulate?
    Jun 2008
    1838
    Quote Originally Posted by airbrush View Post
    I think you will have to save the file out as a .nc file, don`t know if you would get away with just trying to re-name the extension, worth a try
    As for the process, sorry but I can`t help you there, need someone else to jump in here
    I have always used my Predator Level 2 to backplot any G code I needed to check so never got around to trying out the Module Works simulation in BobCAD.
    Regards
    Rob
    Oct 2007
    446
    there are some open source simulators you can load up gcode into....just wanted to know if bobcad can do this as well???
    Jun 2016
    4
    Hi all!
    Can anyone point me in the direction of an open source simulator that works well? my bobcad simulator has not worked since I re-installed my program onto a different computer, and bobcad will not support version 22 anymore. Thank you in advance!
    Quote Originally Posted by happynow View Post
    I'm reliably informed it doesn't support peck drilling but Camotics looks fairly promising,
    - Nick
    Jun 2016
    4
    Quote Originally Posted by magicniner View Post
    - Nick
    Thank you Nick! I will take a look at that one.
    Thanks again John.
  1. Weird Simulation View
    By fidia in forum BobCad-Cam
    Last Post: 09-23-2015, 07:28 PM
  2. simulation and training software???
    By presiyan in forum Community Club House
    Last Post: 02-13-2014, 03:02 PM
  3. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  4. CNC FANUC Simulation software
    By DamoDamo in forum Mentors & Apprentice Locator
    Last Post: 04-10-2011, 06:05 AM
  5. mazak software/simulation
    By Trogdor in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-26-2009, 08:18 PM
