586,108 active members*
3,131 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > VAC Unit for Okuma Cadet CNC
    Dec 2010
    12
    Any ideas of why the VAC unit is overheating?
    Apr 2009
    1262
    Re: VAC Unit for Okuma Cadet CNC
    Check the simple stuff first. Is the fan running? If not, check the fan fuse or replace the fan. Is the heat exchanger clean? Then try the VAC at different RPM's. Watch the load meter to see if there is excessive load on the drive when non-cutting. It should be almost nothing at low RPM and probably less than 15% at a high RPM.
    Best of luck,
    Experience is what you get just after you needed it.
    Dec 2010
    12
    We did find that the fan is not working, finally found one online. So we are going to start with that. Thanks for all your help
    Jun 2015
    4154
    We did find that the fan is not working, finally found one online...
    hello, as okumawiz just said, i was going to suggest you a step-by-step approach ... actually, i would suggest to plug in your machine you know, like to check simpler and obvious things 1st
    about that fan, also verify if it receives power ... if yes, than it is broken ... if not, than is something else
    make a heat diagram on your motor ... hope there is no problem inside
    also, about fan replacing ... if it runs faster when motor gets hotter, than replacing it may solve things temporaly ... if it always spins at same rpm, just replace it
    compare heat diagram with one from a similar engine
  1. Okuma Cadet OSP700L
    By SINUMERIKO in forum Okuma
    Last Post: 03-01-2021, 05:45 PM
  2. crt monitor for Okuma Cadet
    By 3DDonn in forum Okuma
    Last Post: 06-19-2016, 01:21 AM
  3. OKUMA cadet 4020
    By GarouBlacknight in forum Okuma
    Last Post: 03-18-2016, 02:29 PM
  4. Okuma Cadet LNC8-VAC Unit overheating
    Last Post: 09-13-2012, 05:17 PM
  5. OKUMA CADET MATE
    By Antonio Arguijo in forum Okuma
    Last Post: 10-09-2011, 02:26 PM
