586,077 active members*
3,711 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Pantograph for inlay work
    Nov 2014
    724
    Just now saw this sub topic and thought I would chime in with the pantograph I just built -
    A few weeks ago I finished the pantograph I designed for doing inlay work on guitars. This was initially for use with my Dremel and flex cable. I did one simple test with it and that worked fine but I’ll do some more before I cut into some nice exotic wood or Abalone. Since I built and posted the video I have modified the pantograph to mount my Dremel directly because I discovered the flex cable chuck runout was too great to do accurate work. Also, I have added a micro-adjustment to the stylus since the video.
    It’s very smooth and precise so I’m pleased with that part of it. It will do 2:1, 3:1, and 4:1 reductions.
    My target testing piece is in the upper right hand corner of the video -
    Attachment 322748
    Attachment 322750
    Attachment 322752
    Micro adjustment stylus -
    Attachment 322754
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Dec 2007
    2134
    Re: Pantograph for inlay work
    Very nice construction! Looks great!
    I used to do a lot of ad-hoc small signs years back and used an old Vermont American pantograph, but yours looks vastly superior.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Nov 2014
    724
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    Thanks, Ian! That's quite a compliment!
    David
    David
    Romans 3:23
  1. CNC system for pantograph
    By dtw in forum Engraving Machines
    Last Post: 12-19-2018, 11:57 AM
  2. software for cnc inlay work
    By rossp in forum Uncategorised CAM Discussion
    Last Post: 12-31-2015, 06:53 PM
  3. intarsia and inlay work with the laser
    By woodman08 in forum LOGILASE Laser
    Last Post: 09-16-2015, 02:26 PM
  4. v-carve inlay work
    By rlrhett in forum MadCAM
    Last Post: 12-27-2014, 12:52 AM
  5. Mini Mill for inlay work
    By Voyageur in forum Benchtop Machines
    Last Post: 11-05-2010, 04:32 AM
