586,103 active members*
3,813 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Exporting of feed rate and spindle speed?
    Jun 2012
    20
    I used to have a CNC Shark Pro and recently purchased a new machine. Now this is probably a post processor issue but is there somewhere in Vcarve, or CUT 3d for that matter, that you have to specify to export those two pieces of data?
    It only shows what seems to be XYZ coordinates. I would appreciate any tips. Thanks.
    Regards Peter.
    Mar 2008
    1762
    Re: Exporting of feed rate and spindle speed?
    Peter...
    Are you using a post processor that is intended for your machine? Browse thru the list of available posts when saving toolpaths. There are hundreds, make sure you the proper one for your machine.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Jun 2012
    20
    yes, it was actually sent to me by the manufacturer. I've got an e-mail off to him as well. He mentioned to check Vcarve for any setting that may have to be tweaked. Funny thing is if I export to CNC Shark, which I used to have, the feed rate is there as F- but nothing for this new machine. IT's strange because this is a more robust professional machine and should be using federate and spindle speed from the software. I think right now it is just cutting at high speed and highest feed rate, which is going to cause problems with some of my machining. I can adjust manually but shouldn't have to. Thanks.
    Regards Peter
    Mar 2008
    1762
    Peter...
    You are correct. Assuming you have a branded machine, then the manufacturer should be able to point you to the proper post or provide one. It is highly unlikely that an OEM would not know the proper post, but in any case you should be able to modify one that is close to get the output that you require.
  1. Exporting of feed rate and spindle speed?
    By pshupe in forum Cut2D / Cut3D
    Last Post: 06-07-2016, 01:50 PM
  2. About feed rate and spindle speed
    By yanlo in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2009, 12:34 PM
  3. spindle speed/feed rate
    By lamed in forum MetalWork Discussion
    Last Post: 06-03-2009, 12:25 PM
  4. CNC feed rate and spindle speed
    By misc.garfield in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-30-2008, 12:20 AM
  5. Spindle speed & feed rate on a Taig
    By Stuff-Builder in forum Taig Mills / Lathes
    Last Post: 08-29-2005, 11:01 PM
