586,537 active members*
2,918 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Need help! Mazak VQC 15 40 mfd. 1989 electrical wiring diagram for BB21A wanted
Results 1 to 15 of 15
    May 2012
    19
    Hello
    I started retrofitting this machine assembled in 1989 in UK and encountered trouble with the rewiring.
    The machine came without the electrical diagram.
    I did remove from the machine FC335M NC controller.
    X, Y, Z axis driver MR-S1, MR-S11 and servo motors.
    The parts removed are useless to me if anyone needs them let me know maybe we can trade something for the electrical manual.
    I installed:
    MR-J2S 750W servos instead of the old HA-83C .
    Mesa 7I77 card with 5I25.
    I need the wire map of INPUT and OUTPUT from the board BB21A, BN624A942H01.
    Can I get some help with the BB21A pins/connectors?
    Razvan
    Re: Need help! Mazak VQC 15 40 mfd. 1989 electrical wiring diagram for BB21A wante
    Is yours Mazatrol M32?
    May 2012
    19
    Hello,
    Our NC was a M32. We did remove it and we use one PC with LinuxCNC.
    Razvan
    Ok, I have the same machine, I will try to help you. I am a machinist, not a electrician. Please, confirm the picture, if it is your board.Attachment 323110
    May 2012
    19
    Quote Originally Posted by EliseoMonteverd View Post
    Thank you for the answer.
    The board in your drawing is the same with the one on my machine..
    I need the pins/wires that are connected to that board to connect them to the Mesa 7i77 board.
    We did replace the Mazatrol M32 because we got a parity error. I did exchange all the boards on NC controller and did not found the problem.
    Attachment 323112
    Thank you,
    Razvan
    May 2012
    19
    Retrofit progress:
    Here is the machine cabinet with exchanged servo drivers and NC.
    I did prepare the machine for five axis. I did install one Granite Argon servo driver capable of driving old HA83C servos for testing only. I will replace it with MR-J2S-70A later on.
    Attachment 323114
    And the naked machine after a lot of cleaning and cleaning. It was extremely hard to remove the dried deposits of oil and coolant.
    Attachment 323116
    Razvan
    Very good job! Congrats.
    I also had problems with the control.
    Send me your e-mail, so I will send you some electric manual pictures.
    Sorry, I do not have enough time to take pictures to the hole manual, so I wiil try to help you, as much I can.
    Nov 2017
    help me me podrían pasar el diagrama VQC15/40 ELEMENTARY DIAGRAM BN065C043 F01-1
    Eleazar, creo que puedo ayudarte. Me pasas tu email o whatsaap por mensaje privado ?
    Enviado desde mi GT-I9500 mediante Tapatalk
    hello
    could you please send me this manual??
    Did you get electrical pictures from somewhere? If you got it, could you send me a copy? I need to find the machine i / o ports. mail: [email protected]
    Best Regards,
    Tuure Kemppainen
    And so whats results?
    I buying also vqc 15,and i also want change controller,else my trasformator is broken..
    Mar 2024
    Good morning, could you also send the electrical manual, thanks
    [email protected]
    Mar 2024
    [email protected]
  1. electrical wiring diagram
    By CPatten in forum Bridgeport / Romi Lathes
    Last Post: 11-18-2017, 08:17 PM
  2. Cincinnati Hawk TC 150 electrical wiring diagram
    By miroksp in forum Machinery Manuals / Brochures
    Last Post: 01-06-2014, 10:41 AM
  3. Powertron servo wiring diagram wanted
    By jeep534 in forum Bridgeport / Hardinge Mills
    Last Post: 02-22-2013, 03:27 PM
  4. Electrical wiring diagram of KALLENBERGER KALCO 70
    By Nosheen in forum Machinery Manuals / Brochures
    Last Post: 09-22-2012, 06:43 AM
  5. need mazak sqt18ms_2 electrical diagram
    By mostafajafarian in forum Machinery Manuals / Brochures
    Last Post: 07-16-2012, 04:21 PM
