586,036 active members*
3,436 visitors online*
Results 1 to 7 of 7
    Jan 2008
    19
    rack and pinion interference issue
    Hi all,
    I have been slowly getting a 4x4 pro machine up and running. Ran into an issue.
    the left side of the x axis pinion gear is making contact with the aluminum and does not appear to be hitting the rack square. the right side looks fine.
    I took the pinion assembly back apart, everything seems as it should. I feel like with as big of a difference from left to right, the problem should be obvious??
    any ideas?
    thanks!
    landon
    Jan 2008
    932
    Re: rack and pinion interference issue
    Can the pinion go further in on the shaft on the left side motor?
    Wood neophyte.
    May 2012
    114
    Quote Originally Posted by Arbo View Post
    Check the thickness of the shim washers that go between the spindle and the pinion plate. I've seen one be thicker than the other
    Dec 2006
    86
    It''s the rails not the rack. Examine the rails
    Jan 2008
    932
    Ah yeah, the rails do seem to be further 'in' on one side than the other.
    Wood neophyte.
    Aug 2011
    107
    Can't tell whats going on with your pinion, your right side looks to be the same clearance as I have on both (1/8" ~ish). I would pull both sides and compare the parts.
    I like what ya did with the prox switches.. What are they touching off / sensing on the front though?
    Jan 2008
    19
    Quote Originally Posted by ericclinedinst View Post
    you may be onto something. the left side wash is .5mm thicker than the right. this would certainly help. I will have to find a thinner washer.
    As for the prox switches; i didn't like having the switches being the furthest most point on the machine, as they looked likely to get damaged.
    I used a chunk of plate up front, and two redheads out back to p/u the switches.
    the design was modified so the table could be flush against the wall. this saved some valuable space, and allowed me to redhead the table to the block wall for stability.
    Attachment 322978
    Attachment 322980
    thanks!!!
    landon
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Replies: 3
    Last Post: 05-05-2015, 04:16 PM
  3. Ballscrews or rack and pinion? What module of rack and pinion is the best?
    By masinecc in forum DIY CNC Router Table Machines
    Last Post: 04-13-2015, 06:04 PM
  4. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  5. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
