586,108 active members*
3,218 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas high speed machining hsm
Results 1 to 8 of 8
    Jul 2014
    221
    guys today I've turned on hsm option, but next to it is the "T" letter, does it mean the parameter is in test mode because I've found out online that this option came free for 100 hours of use for some people.
    ive got 2016 haas vf2 which is paid and unlocked (no activation codes necessary each month).
    am i free to use it unlimited or is it 100 hours and bye-bye?
    Jun 2016
    4
    Re: Haas high speed machining hsm
    The letter T stands for time trial. what I do is turn it on use it then turn it off when i don't need it. I've used the scaling and rotation for months because i just use it for a few min or hrs then turn it back off. I actually used the macro trial. wrote the simple prog. then turned it off and it still works three months later. ha ha Haas
    Jul 2014
    221
    wait a minute, macro trial for what? scaling and rotation? i dont need that, i need hsm.
    how do i know how many hours do i got left?
    Nov 2006
    490
    I don't think there is an hour counter anywhere, it just shows a "T" if you have time left, but no indication of the exact amount of time. that's pretty much how all the software options work, for anything that is marked as a trial in your parameters page. If you were to forget about the option and leave it on, it'll count down and next thing you konw it'll be gone.
    15362
    Quote Originally Posted by allenp View Post
    You keep a check on the time you turn it on/off, write it down
    Mactec54
    Mar 2010
    84
    I will give Haas credit, one nice addition to the NG control is that it keeps track of trial option time and counts it down for you.
    15362
    Quote Originally Posted by DruMor View Post
    I think it is on some of the pre new generation control, I never tried them I brought the important extras so never turned them on, just put the code in
    Mactec54
    Jul 2014
    221
    what that?
  1. What is high speed machining
    By Klox in forum Hard / High Speed Machining
    Last Post: 04-11-2014, 05:13 AM
  2. HAAS VF2-SS High speed machining 15-5.
    By hairball in forum Videos
    Last Post: 09-18-2013, 07:44 PM
  3. high speed machining (High RPM)
    By bucketbot in forum MetalWork Discussion
    Last Post: 06-14-2012, 09:34 AM
  4. High speed machining
    By cncwhiz in forum Fanuc
    Last Post: 12-05-2009, 01:07 AM
  5. high speed machining ?
    By ssrmr2 in forum OneCNC
    Last Post: 11-18-2008, 03:18 AM
