So before the tool starts cutting i always get a z movement...the tool goes up and comes back down to start cutting...i'm assuming its adding in my clearance plane setting before starting...here is an example of some code below.
The top of my material is 0.855 and my clearance plane of 1". You can see there is a z movement of 1.85 at the start. Wondering if this is a normal thing or can be edited as part of the post(attached my post)?
I usually set my x/y zero first and then my z zero, in this case bottom of part.
Its not a huge concern for now, but just thinking for down the line if i add a 4th axis to my machine, i'll be starting with z up higher and don't want to hit limits....
(FIRST MACHINE SETUP - Machine Setup - 1)
(PROGRAM NAME - A_LETTER.TAP)
(POST - BC_3X_MILL 3-AXIS GENERIC FANUC)
(DATE - TUE. 05/24/2016)
(TIME - 07:37PM)
N01 G00 G17 G40 G49 G80 G20 G90
(FIRST CUT - FIRST TOOL)
(Machine Setup - 1 Z Level Rough)
(Z LEVEL ROUGH)
(TOOL #1 0.25 1/4 2 Flute LOC 1.125 Carbide)
N02 G90 G54 X6.4138 Y-7.4739 S5347 M03
N03 G43 H1 D1 Z1.85
N04 Z1.0855
N05 Z0.9295
N06 G01 Z0.767 F31.0161
N07 X6.2167 Y-7.3325 F62.0322
