Hi All
I'm new to this forum. I had a very stupid question and I don't seem to find any answer on the net. Maybe I'm just not looking good enough?
Years ago I received a very small CNC from a friend. An old 2020 Chinese CNC,that I can't even find the model any more.
The problem is quite clear but still I don't know how to fix it. Whenever I have the stepper driver ON and I switch ON the spindle the stepper motors start moving by themselves, completely erratically.
Good, so I know what is causing the movement, is the electric noise coming from the spindle (or any other motor, I've tried the vacuum cleaner and a corded drill with all same result). Also noticed that when I plug the spindle to a different phase the motors stop moving erratically. Good, so it's the spindle. But just half a year ago I moved to a new studio and now I don't have 2 separate phases anymore and I'm stuck.
I've also done some measurements:
voltage between earth and GND (out of the Power Suply of the stepper driver) is about 1.5 V (should that be zero?)
voltage between earth (at the socket) and chassis (at the computer) is 0.06V when ON.
Voltage measured between the spindle and ground is incredible and with huge spikes
So the question is:
What is the best thing I could do in this situation?
I have some clues but I could be trying forever before finding the real one.
Options:
1- Filter the spindle to remove noise
2- Filter the driver to make it immune to noise
3- Opto-Isolate connection between computer and driver (don't know why but I have the impression that could be related)
4- Isolate Motors Power supply
and of course other options would be:
buy a new better spindle
buy a better driver
buy a better Power supply
So maybe you will scream at me cause the answer is obvious but still haven't find anyone that could help me. Please enlighten me
Many thanks!
My setup:
Since I got this CNC from a friend I never had the exact model but looking on internet I found a close match:
CNC driver controller: Chinese TB6560 CNC Stepper Motor Driver Controller Board 3 V3
Aluminum Box CNC Router 3 Axis 3.5A TB6560 Stepper Motor Driver Board Controller $62.30 Free Shipping @GoodLuckBuy.com
model 2020 mini 3D CNC router/milling
[*]X-Travel: 210mm/ 8.25"[*]Y-Travel: 190mm/ 7.50"[*]Z-Travel: 75mm/ 3.00"[*]Table Size: 250 x320 mm/ 10"x 12.5"[*]Interface : NcStudio breakout board(insert to computer Slot with 15 pins) or Mach 3 breakout board (25 pins port of computer)[*]Shaft size: X Axis:13mm Y Axis:16mm Z Axis:12mm[*]Lead screws: M10x1.5 pitch (mm)[*]Feed Speed: 1800mm/min (1500mm/min Recommend)[*]Repeat accuracy: Better Than 0.04mm/ 0.0015"[*]Machine Size: 385/380/390 mm 15"/15"/15.4" (Length/Width/Height)[*]Packing Size: 440/440/460 mm 17.4"/17.4"/18.1"(Length/Width/Height)[*]Machine weight: 13kg/29pounds[*]Gross Weight: 13.5kg/30pounds
