586,060 active members*
4,275 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > 3D Roughing/Finish Tool Path Not A Smooth Edge V Carve Pro 8.5
    May 2007
    7
    Need a little input for rough edges.
    Milling a fishing lure mold, materail .50 Delrin. My edges of lure are coming out rough. The bottom surface of lure is fine. I attached a photo which shows edge cut.
    My conditions and perimeters...
    3D Roughing- .1250 ball end mill, .0625 depth of cut, step over 0.0025 2% ,30 IPM ,Machine allowance (.02), Z level (Raster X), Profile-(Last)
    3D Finish- .1250 ball end mill, .0625 depth of cut, step over 0.0013 ,40 IPM ,Raster (45 degree)
    Your thoughts are appercaited. Thanks.
    Mar 2008
    1762
    Re: 3D Roughing/Finish Tool Path Not A Smooth Edge V Carve Pro 8.5
    Setup a machining boundary to restrain cutting just "to" , but not over the edge. Then use a 2d profile to cut the edges.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    May 2007
    7
    Thank you for the reply. Do you know if a tutuorial is available for your recommendation? I am trying to remove the scallops from the wall edge.
    Mar 2008
    1762
    I cannot name a specific tutorial that pertains to this, but there are numerous threads on the Vectric forum that give both instruction and examples on how to accomplish exactly what you are looking for.
    Feb 2009
    192
    it will never be 100% smooth, you will have to do some manual finishing
  1. 3D Tool Path Options : Advance Roughing
    By aldepoalo in forum BobCad-Cam
    Last Post: 09-03-2013, 06:08 PM
  2. Rogue Tool Path on Finish Pass
    By Inventherm in forum BobCAM for SolidWorks™
    Last Post: 05-31-2013, 03:52 PM
  3. Adaptive Roughing Tool Path
    By jrmach in forum BobCad-Cam
    Last Post: 05-12-2013, 01:50 PM
  4. Roughing tool path questions
    By lpmfg in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-15-2010, 10:38 PM
  5. Need Smooth Finish Please
    By Hoover in forum WoodWorking Topics
    Last Post: 01-18-2008, 12:47 PM
