Re: Stepper motor troubleshoot
If I read this correctly, the only thing left is the PC... The drivers are connected to a parallel port? It's the port or the configuration as Louis suggested. If the config hasn't changed, or you verify it's correct, then the problem is the parallel port. If it's a desktop, buy a parallel port card (they are cheap). If it's a laptop... look into a USB connected motion controller... (NOT one from China!) or get an old desktop to replace the laptop. Those are often available for next to nothing.... or even nothing...
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
