586,103 active members*
3,746 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Mounting linear rails on aluminium
    Jun 2016
    Hi All,
    I'm new here and have done some searching, but can't find a definitive answer.
    I'd like to build a 3D printer that is actually built to some sort of tolerance, using Hiwin EG15 precision rails mounted on a welded aluminium chassis if possible.
    I am aware of the need for a precision surface and reference edge, and this is where I'd like to get it right, unlike so many 3D printers where a precision rail is bolted onto a sheet of tin or even floated unsupported.
    My plan was to make at least the top (XY) and rear (Z) panels in a solid welded construction by pre machining, fabricating and post machining in the rail mounts. The idea being that while we are not trying to build a full blown CNC machine, we are building something rigid and precise enough to possibly support use as an engraver etc further down the track.
    If I am going to the trouble and expense of doing this, I feel I'd better consider thermal expansion of the aluminium and it's effect on the linear rails.
    The build volume will be 300x300x450/600, and the cabinet around 550x500x750/900.
    I'm looking at using 6 or 8mm 6061(I think) plate.
    Obviously a brief description, but if at a glance it's obvious that expansion is an issue I'd rather take a different tack from the start.
    While 3D printers don't require the kind of tolerances needed in CNC machines, I notice that the methods/materials used in printers are getting shoddier and shoddier, which is why I came here.
    I'm looking to build something solid, reliable, repeatable and transportable, and in particular aligned correctly.
    Point of interest would be that I plan to use the corexy configuration, which I understand is more common in CNC machines?
    The machine will be enclosed, somewhat like a small bar fridge, and will get up to around 40-55 degC inside.
    Mar 2010
    12
    Re: Mounting linear rails on aluminium
    It's not really clear what your question is...
    Jul 2018
    16
    HI,
    Good day!
    We are cnc machining factory in china , if you have Mechanical Design metal parts feel free let me know, send us drawing ,we provide high quality and good price products for you.
    Thank you!
    James
    E:[email protected]
  1. mounting rails to 80/20
    By 3Dsigns in forum Linear and Rotary Motion
    Last Post: 11-13-2012, 05:31 PM
  2. Mounting Profile Rails
    By Falcon69 in forum DIY CNC Router Table Machines
    Last Post: 08-12-2012, 05:54 AM
  3. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
  4. mounting location for rails
    By kevintshaver in forum Linear and Rotary Motion
    Last Post: 03-02-2009, 05:52 AM
  5. mounting linear rails side by side
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 10-24-2005, 01:49 PM
