I was thinking of something like this and go from there build the bridge from this unit size
here are the spec 5 inchs travel 4" WIDE
FOR NEMA 23 MOTOR
*****Use 75oz/in - 450oz/in motor with 1/4 shaft*****
for 3/8 shaft, ask for the right coupling
machined from 3/8 plate 6061T6 alu.
SS 3/8-16 SCREW WITH ACETAL NUT
DOUBLE SS BEARING ON ONE END
ACETAL BEARING
LOW PROFILE, ONLY 2.625"
VERY COMPACT UNIT with FLAT BACK
WEIGHT +/- 4.4LBS WITHOUT motor
FRONT PLATE WITH 6X 5/32 MOUNTING HOLES
(they are not in the actual picture)
PLAIN BACK PLATE
(we can make mounting hole for you, ask)
FRONT PLATE IS 4" X 5"
BACK
Originally Posted by
awerby
My preferences aren't particularly relevant here. You need to decide how much clearance you need between the top of your highest part and the tip of your longest tool, bearing in mind that the lower you keep it the more stable your machine will be.
It's pretty common to use dual slaved motors and screws to run the longest axis, which halves the load on each motor as well as avoiding the "stuck drawer effect".
