586,117 active members*
3,499 visitors online*
Page 1 of 16 12311
Results 1 to 20 of 318
    Mar 2014
    735
    2nd build - For a friend
    Hi All -
    About 3 years ago I started building a CNC router. Used it for just a little while and quickly embarked on an upgrade. The upgraded version turned out pretty well. Very accurate. Not perfect but good enough to learn on as I have no machining experience. Its rack and pinion drive on the X and Y and a ballscrew linear actuator for the Z and NEMA 23 steppers all around . I used a lot of parts from CNC Routerparts.com, NEMA 23 motors, their PRO motor mounts, rack mounts for the rack and pinion gear and a few other things. I used off the shelf parts in critical areas where I felt that my skills were only marginal and the better solution already existed. Just had to pay the man. I built the homing and limit switches for it from the thread on here and that turned out well.
    I've done a few things for people now and one of those was for the local Boy Scout troupe. They were building kayaks and each kayak had about 12 frames for the structure. I think there were about 12 kayaks in total so this involved a lot of parts but a lot of repetition. Perfect for a CNC router. The job went very well and I was glad I could contribute.
    So my friend is a incredibly talented woodworker and his son was one of the Scouts and he liked my router. About a year later, his wife approached me discretely and asked if I could build one for him for his 50th birthday. I had learned a lot since building my first one and I wanted to build another one but I didnt need one or have room for it. But I would love to build one for a friend I jumped at the chance. So this will be the chronicle of my 2nd build. I'm open to suggestions so share them if you have them.
    Design goals:
    1 - Reliability. This is going to get turned over to someone else. It has to be user friendly and it has to be stone cold reliable.
    2 - Speed. Time is money. The faster it works, the more time it can be used. My friend is a busy guy.
    3 - Precision. I would like it to be able to hold +/- .005" when machining hardwoods. Not sure if this is unrealistic but I think I can get it rigid enough to achieve this.
    General design information:
    I want the cutting envelope to be 6ft in the Y and 4 ft X, with 6" of travel for the Z.
    The Z will be able to travel outside of the cutting envelope in the X plane. Mostly for touch reference probing off the bed.
    No sidewalls on the cutting bed. Nothing for the tool collide with and this makes the workpiece more accessible and easy to fixture.
    Motivation will be NEMA 34 ClearPath Servo drives on the X and Y and a NEMA 23 on the Z. Sevo's over steppers so no lost steps.
    Machine base will be welded steel.
    Machine frame 8020 T-slot extrusion.
    Profile linear rails and Hiwin or THK bearings on the X and Y.
    Rack and pinion drive for the X and Y
    UCCNC for motion control as this is what I'm using now and MACH 4 seems to be unrefined(?). UCCNC works fairly well. And I can explain how to use it to my friend when this is delivered.
    For a BOB Lots of options. Was considering the Leadshine drive from CNC router parts but the Clearpath Servo's only need step and direction commands. Not sure yet. Any suggestions??
    More to follow
    Pic is of my first CNC router after upgrade cutting out the kayak parts.
    Mar 2014
    735
    Re: 2nd build Z-axis arrived
    The Z-axis linear actuator arrived today. I'm using a Kollmorgen DS4 linear actuator I sourced as new, surplus from E-bay. Its a ballscrew drive, 5mm pitch with a 150mm stroke, NEMA 23 motor mount. It also has a built in clutch that prevents damage if its driven past its travel limts. Its paperwork says it was tested to slip at 16oz/in. This seems a little light and I may have to restrict the torque or acceleration on the Z-axis drive motor to ensure it doesnt slip under normal operation. I have a similar actuator on my current router and it works well. I'll test it when the time comes. Aside from that Its a beefy actuator and sealed well to protect it from the all the debris the Z-axis has to contend with.
    Looks like the forum is being a little finnicky for uploading pics. I'll have to add them later. Got to go pick up the steel for the base
    Mar 2014
    735
    Re: 2nd build - For a friend
    Steel. Its all 3/16th wall. Main beams are 4x4. Stretchers and braces 4x2. Click image for larger version.
    Sent from my VS980 4G using Tapatalk
    Mar 2014
    735
    Z axis. 150mm travel, Kollmorgen ballscrew linear actuator. NEMA 23 mount and i had a proximity switch already that mounts neatly in the slot thst will be the home switch. Attachment 323830
    Mar 2014
    735
    Good progress today. Attachment 323940 we layed out the frame and then made up 4 leveling pads. I had some well nuts and i used them in 4 corners of each pad. Attachment 323942
    Mar 2014
    735
    Inserted 1/4 20 bolts into the pads and placed the pads under the beams at all four corners. We used a rotary laser level to project a reference plane and a straight edge ruler to measure down to the pads from the laser beam. We adjusted the leveling pads until they were all the same distance down from the laser Click image for larger version.
    Mar 2014
    735
    We got it very flat using this method. Within a 1/16th or less on each corner. Meadured diagonally across the corners and squared it up then we used some ratchet straps to hold it in position and then we tack welded all 4 corners.Attachment 323966Attachment 323968
    Installed some flat stock across all 4 corners to hold it square and proceeded to weld it all up.Attachment 323970Click image for larger version.
ID:	323972Click image for larger version.
ID:	323974Click image for larger version.
    Mar 2014
    735
    Thanks goes to talonosi for giving me the idea of using the leveling pads. His thread is in the CNC Router Parts forum. Good thread with lots of tips.
    Mar 2014
    735
    Started on the diagonal braces today Attachment 324284Attachment 324286Attachment 324288
    Mar 2014
    735
    Finished the day with all the braces tack welded in place. I measured the squareness of the bottom of the legs to see if the braces had pulled the legs inward. They did a little. The long dimension at the end of the legs had pulled in about 3/4 inch. The short end pulled in about 3/16. I dont think this will affect anything as i planned from the outset to epoxy level the top to make a flat surface for the extrusion. I'll get some measurements when we flip it upright to see if its severly twisted. I dont think it is as we would have never noticed it if we hadnt measured. But just i case, im researching post weld heat treatment providers in Michigan to get it stress relieved. Attachment 324290
    Mar 2014
    735
    I was mistaken. The braces only pulled the ends in about 3/8". Across 7ft that is just fine. We flipped it over and checked for square and flatness. Square was dead on. I used a 48" ruler for a straight edge and it appeared the corners had pulled down less than a 1/16th. That seems very good. The epoxy pour will level it out quite nicely
    Mar 2014
    735
    Attachment 324374
    Took a pic while we had it flipped over.
    Starting now to work on installing some temporary casters so we can move it around easier while we build it. The casters will be removed once its in its final location and be replaced with leveling bolts.
    Mar 2014
    735
    Attachment 324466
    Finished fabricating the base. Next step sandblast and primer.
    Mar 2014
    735
    Started sandblasting and abrasive prep for primerAttachment 324854Attachment 324856Attachment 324858
    All set.
    I blasted the top surface more aggressively to etch it a little deeper for the epoxy.
    Mar 2014
    735
    Today was a perfect day to spray. About 74 degrees, low humidity and clear skys. The paint gun is a nice one that my Dad bought for restoring a couple Allis Chalmers tractors. The primer was a 2 part mixture of primer and activator mixed in a 4:1 ratio. It turned out great. Attachment 324860Attachment 324862Attachment 324864Attachment 324866
    Front end loaders really come in handy!
    Mar 2014
    735
    Im waiting on the engineering firm to finalize my extrusion order from 8020. I could have ordered directly from 8020's website but i found that out after i contacted the engineering firm who is an 8020 distributor. You get a discount by ordering through them and, they AutoCad your design and verify everything is correct. Its taking them a couple weeks. I guess im low priority. But im ahead of schedule so its not an issue yet. Ive still got to order from Precision Epoxy and decide on a design for the gantry risers. Precision Epoxy is gone until July .
    Mar 2014
    735
    Attachment 325242
    4x3x1/4 and 5x3x1/4 angle iron. These are going to become part of one gantry riser.
    Mar 2014
    735
    Attachment 325470
    Some days i really wish i knew AutoCad Ill get it drawn up. It'll just take me a little longer. Plus, i get to think a little more about the design which i hope the extra time spent in planning will avoid mistakes in execution. The master design is in my head. Getting it onto paper is sometimes a little challenging.
    Mar 2014
    735
    The angle iron is going to form the upper and lower parts of the gantry risers. The lower piece is the 3x4. It bolts to the sidemounted linear rails and turns over the top of the frame and provides a 3" flat plane. It will also provide a mounting point for the CNC Router Parts Pro motor mount.
    The upper part is the 3x5 angle. Its 3" face will be bolted to the 3" face of the lower angle iron and its 5" face will turn upward and bolt to a short piece of 40 series extrusion which in turn will anchor to the bottom of the X gantry extrusion. The face-face mounting technique will let me employ some conformal shimming (epoxy joinery/bedding) if i need to, to get my X gantry exactly perpendicular to the cutting bed.
    Mar 2014
    735
    Attachment 325476A pic is worth a thousand words. This is conceptual mock up of the gantry riser.
Page 1 of 16 12311
  1. CNC Router Build For A Friend
    By mactec54 in forum CNC Wood Router Project Log
    Last Post: 04-05-2019, 05:15 PM
  2. Looking for a Friend
    By ltmquik in forum Fadal
    Last Post: 05-08-2010, 05:17 PM
