586,104 active members*
3,332 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Anyone tried ultrasonic milling?
Results 1 to 7 of 7
    Jun 2014
    777
    Hi there, just heard about these ultrasonic tool holders and ultrasonic spindles that use piezo vibration generators in the tool holder or spindle to vibrate the tool and the efficiency benefits of this.
    It's mostly aimed toward metal milling but I'm wondering if this efficiency increase would be found if it was applied to routing of wood.
    Any one had any experience with these?
    Cheers
    Jon
    Apr 2004
    5737
    Re: Anyone tried ultrasonic milling?
    I've heard of it being used to carve stone, drill beads, and make cameos. But I've never heard of it being used on wood.
    Andrew Werby
    Website
    Jul 2008
    11
    Jun 2014
    777
    Thanks for your replies, so your verdicts, does anyone think it could improve efficiency cutting wood? I go through around £200 in bits a month, I read that with ultrasonic they see tool life increase by 40%. So there's a chance it could save me a thousand a year in tool wear I'm intreagued.
    Could be that wood would dampen the vibration, I have no idea.
    Apr 2014
    432
    That's a lot of tooling a month ,I was Interested in Taylor guitars machines they say that they can carve 1,000 plus necks with one tool .
    Jun 2014
    777
    Quote Originally Posted by InMesh View Post
    What tool would that be? ball nose carving the bits last longer, contouring ply all day with 1/4" compression spirals because the part clearance is not big enough to use larger bits. A quality £50+ bit will just about last a pallet of ply (30 sheets) checked with msnufacturers and was told that was as expected. Onsrud lasts the longest and will get through 30 sheets but dulling is evident on the finish in last few sheets.
    1000 hardwood necks start to finish and still be sharp tho, I very much doubt that. Large diameter 1/2" + bullnose used for finishing only then possibly.
    But carving hardwood and cutting lamininate are two diffrent games all together.
    Apr 2014
    432
    I got you yes just raw wood is what they do large ballnose cutters ,the ply you are doing I believe has abrasive glues in it for sure.
  1. Tangential knife - ultrasonic - oscillating
    By Jacala in forum Mechanical Calculations/Engineering Design
    Last Post: 03-27-2019, 07:47 PM
  2. Need Assistance Programming an Ultrasonic Robot
    By MTechStudent in forum G-Code Programing
    Last Post: 11-19-2014, 08:53 PM
  3. Ultrasonic cleaners
    By zoeper in forum Mass finishing equipment/media/strategies
    Last Post: 07-18-2010, 04:55 PM
  4. ultrasonic knife design
    By JNFSWE in forum Mechanical Calculations/Engineering Design
    Last Post: 01-31-2009, 01:10 AM
