Re: Dust collector
Originally Posted by
CadRhino
It is a big mess cutting wood. I have a dust deputy I am going to try. So far my approach has been lots of air ventilation and filtering. I have (2) 300 clear fans that pull air across the back of the tormach and straight outside. I also have a KDS air filter mounted directly above the tormach. With all of that I still get a good layer of fine dust in the shop.
My only concern is if the dust deputy and shop vac will hold up over time. Some of my wood cuttin ops can be 4-5 hours long (really).
I routinely do quite large 3D jobs in HDPE and MDF for molds and the jobs can run for 8-12 hours at a time depending on the degree of finish I'm after, creating an unbelievable amount of waste. And if you've ever done HDPE, that stuff creates an even finer and grittier dust than MDF does, and the Dust Deputy handles it all beautifully. The only time I ever get any dust escape, is when the job machines at the outer limits at the front or rear of the machine and the dust boot hangs in space a bit. But even the dust there is limited to a little build up at each end.
All in all, I couldn't be happier with the DD, it is worth it's weight in gold.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
