586,398 active members*
2,998 visitors online*
    Jan 2007
    Question Fanuc Magnetic Sensor Error
    I have a Fanuc 6M control with a Magnetic sensor for spindle orientation. I frequently get sequence errors because the spindle has difficulty finding orientation in order to tool change. Is there a way to tell if the problem is with the sensor, amplifier or board without paying Fanuc a gazillion dollars for the new parts? Thanks
    Feb 2007
    464
    Does the sensor have a diod so you tell if it's affected?A green or a red diod. Or maybe it shows both colors.Not at the same time of course. Turn the spindle by hand and see if it lights up.If you see two colors(Red and green)the red shows first and then the green.Maybe the sensor is too far away from the cam.
    9 times out of 10 it is the sensor.
  1. Fanuc 5T ERROR 20
    By alduns in forum G-Code Programing
    Last Post: 02-03-2009, 12:15 AM
  2. Fanuc 6MB Error LED
    By tsalpha in forum Fanuc
    Last Post: 01-05-2007, 03:51 PM
  3. Fanuc 6 system error 908
    By hidivsultan in forum Fanuc
    Last Post: 06-23-2006, 02:43 PM
  4. Error L on Fanuc series 10
    By wanchai101 in forum Fanuc
    Last Post: 02-28-2006, 09:09 AM
  5. Fanuc 3T -MODEL A error 5
    By geroda in forum Fanuc
    Last Post: 07-08-2005, 02:39 PM
