586,441 active members*
4,582 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > plz help wiring limit&Home switches to TB6600 board
    Jun 2016
    5
    Hi All,
    Please advise how to wiring limit&Home switches to TB6600 board
    Board link : http://www.omc-stepperonline.com/dow...ers_Manual.pdf
    Jun 2014
    777
    Quote Originally Posted by soolom_1 View Post
    Hi All,
    It's simple. The switch simply shorts the input pin to ground. Setup the port and pin for that particular input and you will see it register. So you attach all your switches to ground pin and one to each of your input pins. No particular order, you order them in the ports and pins configuration.
    Jun 2016
    5
    Re: plz help wiring limit&Home switches to TB6600 board
    Quote Originally Posted by Jon.N.CNC View Post
    Thanks a lot Jon, So I connect all the switches (com) to GND and one to each NC to In1 pin ? should I connect anything to the v5 pin ?
    thanks in advance
    Jun 2016
    5
    Plz close i was able to wire the switches:banana:
  1. G540 wiring questions (home an limit switches)
    By itolond in forum Gecko Drives
    Last Post: 09-11-2015, 04:25 AM
  2. Wiring Limit, Home and E-Stop Switches
    By gpraceman in forum Safety Zone
    Last Post: 05-01-2012, 02:40 PM
  3. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  4. Wiring Home and Limit Switches Efficiently
    By MrAR15 in forum Taig Mills / Lathes
    Last Post: 07-11-2009, 06:44 PM
  5. Wiring home and limit switches
    By Hack in forum CNC Machine Related Electronics
    Last Post: 01-24-2009, 10:47 PM
