Just completed building my machine about a month ago and it's been operational since then. I've been mostly making smaller things in CUT2d to get a feel for the machine and programing and have been happy with the overall results until tonight. I designed a computer cabinet for the machined computer in Cut2d with multiple parts on two sheets of plywood. Most of the parts were rectangular. Cut went smooth but when I started to assemble the cabinet I noticed that a few of the pieces were not perfectly square. They were actually parallelograms - only slightly but enough to bother my cabinetmaking sensibilities. The diagonals were off about 1-1.5mm - the sides were consistent . The strange thing is that I cut essentially four of the same part but two were perfect and the other two slightly off - See photo - the two with the post it notes are the ones out of square but the two adjoining them were perfect. I spent a lot of time dialing things in and went back and checked all the rails and I have a consistent distance between. Is something racking the y-axis, but if so, wouldn't everything be off? When I was positioning the copies in Cut2d did the drawings get racked? I went back and checked and reading good 90 degree angles and consistent measurements. I was about to fire up Mosziak to build cabinets but now I'm a little nervous until I get this worked out.
On a side note - totally bummed when I came on here and found out the Pro has been redesigned - wasn't a pleasant struggle with the v-con - new system looks much easier. I wish there had been some announcement further in advance as I would have held off a few months on my purchase.
Thanks,
Jim
