Re: Stepper motor controller
The pulse test option for our BOB PCB does exactly that. The button click moves the motor one step, a press currently moves the motor forward (or back) 15 steps. Or if you hold the button it will start running continuously.
techref.ecomorder.com/techref/ecomprice.asp?p=416016
Note there are other components necessary to build the kit (the PCB, cable, power regulator, etc...) It is, also, a KIT... you solder it together.
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
