586,076 active members*
3,783 visitors online*
    Jun 2016
    6
    Question cutting **** of 1mm sterling silver
    Hi all,
    Im working on a CNC machine 3axe cutting normally wood. one of my customer ask me if it'll be possible to cut "small names" (the one that goes on a neckless)
    and i wonder if itll be possible to find such a small bit. (max 1 mm). anyone ever did this kind of job here?
    Also ill take adventage and ask for reccomandations for good and also chip website i can get my bits and drill.
    Thanks alot
    Apr 2004
    5737
    Re: cutting **** of 1mm sterling silver
    Yes, you can find small bits . But that's not going to turn your wood router into a precision mill. While the larger bits used for wood are tolerant of a little runout, the tiny ones used for metal, where the runout of your spindle is a much greater percentage of their diameter, will snap. Holding onto the stock is another problem; small pieces of sheet metal are hard to hold down, and tend to rise up and break cutters, which are quite expensive in small sizes: FRAISA eShop - Fräswerkzeuge
    If I had to do this job with a wood router, I'd cut the parts out in wax, which is more forgiving of errors, and send them off for casting.
    Andrew Werby
    Website
    Aug 2016
    83
    Quote Originally Posted by awerby View Post
    totally agree, cnc router used on.woodworking,furnitures, cabinets,advertising, making signs,channel letters more
    Chencan cnc router from 1998.
    skype marylee0411
    Jun 2012
    182
    drillman1 at Carbide Endmills, BARGAIN BIN items in CARBIDE PLUS store on eBay! has lots of small endmills and drills. He also has a good reputation. I've ordered from him multiple times.
  1. CNC Sterling Silver Designs
    By hhjj7777 in forum MetalWork Discussion
    Last Post: 07-15-2015, 09:22 PM
  2. Which laser to cut 1.5 to 2mm sterling silver sheet?
    By altaran in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-08-2014, 08:56 AM
  3. Stamping die for cutting silver
    By Silverworker in forum North America RFQ's
    Last Post: 06-06-2012, 04:08 PM
  4. Machining Sterling Silver
    By Exodus8931 in forum MetalWork Discussion
    Last Post: 11-08-2009, 03:45 PM
  5. Cutting Speeds for silver?
    By novacustard in forum MetalWork Discussion
    Last Post: 03-23-2007, 10:33 PM
