586,114 active members*
3,199 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Tool path not displaying design in the correct position
Page 1 of 3 123
Results 1 to 20 of 42
    Apr 2015
    48
    Hi all,
    Needs some help I have a small hobby mill from open builds running Mach 3, G540, ESS. I down loaded Vectric Aspire demo to design a dust boot, finished the design and find out you can't save the G-code. So I send off a DFX of the design to a friend that does pearl inlay with Vectric to save the design to Mach2/3 arcs.txt, He sent it back to me and loaded it up. Heres the problem all the dust boot plates show up the material on the top right hand side (picture attached). I have reinstalled Mach 3 and tried setting IJ to incremental in General settings. the design should be in the centre of a 220mm x 150mm 10mm work piece of acrylic. Every thing shows in the right place in Aspire is there something I am not doing in the design side that would cause this. I am also trying to to learn Fusion 360 but I drowning on the CAM side and was told by mate to try Vectric software which is great to use. Appreciate any help.
    Cheers
    Peter
    Feb 2006
    210
    Re: Tool path not displaying design in the correct position
    Did you set zero And then move the head? The plot will move the picture in relation to the head. Try setting zero then load the gcode without moving the head out of the way
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Apr 2015
    48
    Hi Beone I ref all home then move to work area probed then zeroed X and Y then regen tool path and didn't move head from there. As this 10mm acrylic here in Aussie land is $49.00 for 2' X 1' piece don't want it go wrong. Can test on mdf but I need to be able to flip the parts in the work area and have dowels for work piece position.
    Peter
    Acoustic and Electric guitars and Basses.
    15362
    Quote Originally Posted by Neptunes View Post
    Hi all,
    Cheers
    Peter
    You need your I/J settings to look like this, check were you part 0.0 is in your drawing
    Mactec54
    Apr 2015
    48
    Hi Mactec54, thats how I have it setup IJ mode Inc and Distance Mode Absolute. I have zero set up on the bottom left the picture I posted.
    Peter
    15362
    Peter
    So your Drawing 0.0 is the same as you machine setup 0.0, if this is correct, then there is a problem with your drawing, or how the code has been processed
    Post your DXF file and what size cutter you are using and I will take a look at it
    Mactec54
    Apr 2015
    48
    Yes thats the deal so far I am currently going through the tutorial of the sample file for Aspire to save the G-code and load it up ind see if my drawing. I will post the DFX, do you want the whole design or just part as its made up of 4 parts ? Thanks for your help mactec54.
    Peter
    Hi I have attached the outer rim design for my dust boot as DXF file, The size of the cutter is Amana tool 1/8th single flute spiral Plastic cutter 1/4 shank 51411 let me now if you need more.
    Peter
    Apr 2015
    48
    Hi all,
    Well I managed to design a simple plate for my dust extractor in Fusion 360 and save a toolpath for Mach 3. This to is showing in Mach 3 Toolpath in the top right corner of the the work material instead of being just off centre. I have attached the G-code and a screen capture of what it looks like in Mach 3. So thats aspire and Fusion doing it and I am trying to get one from Meshcam demo as well. This is doing my head in need to get cutting but this has me stumped
    I f some could load this G-code up and check the position on work piece for me. The work piece is X 205mm Y 225 Z 33mm. There is most likely mistakes in regards to tool choice but I am still learning.
    Cheers
    Peter
    Attached Files Attached Files
    Looks the same here, so I would say your issue is with Aspire and Fusion 360.
    Center is roughly 106,131
    Apr 2015
    48
    Thank ger21 for checking I just did the same dxf in meshcam to and same result . Any ideas were to start looking ?
    Looking at your other .dxf, the toolpaths coordinates match the .dxf coordinates. You need to move the .dxf to where you want it. Either in the CAD program that it was drawn in, or in the CAM program before you create toolpaths.
    Or, in Mach3, just zero your X and Y axis to position the part where you want it to be.
    15362
    Neptunes
    Ok found some time to look at your part the drawing is really messed up,this is what it looks like when I open it, Note where the X0Y0 is, this is part of your problem
    You have lots of lines when they should've just been arc's, I will redraw it, where do you want the X0 Y0 to be, and what is the Radius of the smaller end of the plate
    Mactec54
    Apr 2015
    48
    Hi mactec54 thanks for checking out the dxf. The radius of the smaller end plate is 42mm and the X0Y0 is ment to be bottom left. The work material is meant to be 220X and 150Y and Z10 mm with the design centred 75mm x 110mm. Not sure why there is open vectors as I used the join all open vectors, I thought that is meant to make it all one piece. Cheers mate thank you again
    Peter
    15362
    Neptunes
    See how this looks you should be able to make your tool path with the DXF file
    Mactec54
    Apr 2015
    48
    Wow that's great mactec54 will load it up after I pick up my son from school what do you use for cad/cam if I may ask.
    Peter
    15362
    Peter
    I have most of the popular Programs, GibbsCam is my favorite, this is to spendy for most though
    Mactec54
    Apr 2015
    48
    Hey all, no luck with the DXF Mactec54 sent me. Tried 3 different cam programs Bobcat, Artcam, etc, and all the same result as the last picture I posted, design is in the top right corner. I have attached the G-code from one of the cam programs. Also I have attached my XML incase its something I have screwed up in Mach 3 settings.
    Cheers
    Peter
    As I said in a previous post:
    Apr 2015
    48
    Hey Ger21 that's what I attempted to do centre of the 220 X 150 work area not sure what I am doing wrong, more research on the way.
    I believe that it is.......
Page 1 of 3 123
  1. Need help with Correct tool carousel position in tool library
    By supraman in forum Uncategorised CAD Discussion
    Last Post: 06-07-2016, 12:01 AM
  2. Tool path position is not accurate after loading the file
    By yooneek in forum UCCNC Control Software
    Last Post: 03-12-2016, 04:29 AM
  3. Correct Zero position
    By Forgo in forum CNC Machining Centers
    Last Post: 01-04-2015, 04:04 AM
  4. DeskProto 2D Operation - Not Sure Tool Path is Correct
    By GregGleason in forum Uncategorised CAM Discussion
    Last Post: 04-22-2014, 12:07 PM
  5. Torchmate not following correct path
    By MoparJon in forum Torchmate
    Last Post: 09-09-2008, 07:35 AM
