586,051 active members*
3,712 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Reducing Nodes, Possible??
Results 1 to 7 of 7
    Dec 2014
    187
    Does Aspire or any of the Vectric software allow a way to reduse the Node Numbers? In Inkscape I can select an object and then select "Path/Simplify" and it reduces the number of Nodes. Using a CNC Router I guess the less Nodes the faster the cut?? Have attached 2 images, 1 in Aspire and 1 in Inkscape showing the difference.
    Re: Reducing Nodes, Possible??
    Try the "Fit Curves to Selected Vectors" command.
    Dec 2014
    187
    Didn't seem to change anything, tried each of the settings?
    Did you increase the tolerance?
    Dec 2014
    187
    LOL ... I thought reducing it to 0.001mm was the way to go, changed it to 1mm and SOLVED ... Thanks for straightening me out Ger21
    Mar 2016
    9
    Hi
    I found a solution to this, its not possible to reduce the nodes in vetric aspire. I start my design in Corel Draw, but instead of saving your design in DFX, DWG or AI, format. save your design as PDF and import it Aspire, It reduces the nodes by more than 95 % and processing time is greatly reduced and the cuts are much smoother also.
    Hope this helps, for me it worked like magic. Hope the vetric guys add such a feature directly into aspire in their next release.
    Apr 2005
    304
    I second that. From Corel to pdf and there are muuuuch less nodes.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Replies: 9
    Last Post: 11-06-2012, 09:04 AM
  2. Corel and nodes
    By Teknition in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-11-2012, 02:25 AM
  3. Quintax\Fagor 8070 Problems with CAN Nodes and Sercos Ring
    By AcryNom in forum Controller & Computer Solutions
    Last Post: 04-19-2012, 07:22 PM
  4. Reducing nodes
    By Traneman in forum Torchmate
    Last Post: 04-21-2010, 09:57 PM
  5. Reducing amperage?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-23-2006, 04:23 AM
