I don't own a milling machine, but I would like one. I am also a complete Noob learning from YouTube making little money sitting in a cube.
I have two drill presses, a Skil 10" and a cheap Harbor Freight 8". I've taken apart the cheap one to examine it as it is of no use to me anymore. I've decided to turn it into a lightweight milling machine and at some point in the future turn it into a CNC or chuck it for a real one (NPI). I already have a 3/4hp DC motor I salvaged from an old treadmill and I also purchased a 120v PWM motor speed controller.
My idea is to replace the existing spindle inside the quill with a beefy ER20 tool holder and swap out the bearings as well.
I bought an 3/4" diameter ER tool holder from a US seller on eBay at a price I couldn't resist:
DZ Brand 3 4" ER20 150 Collet Extension | eBay
The existing spindle is 12mm and the quill housing has an inside diameter of 32mm. The quill has two 6201 bearing (12mmx32mmx10mm). I couldn't find a bearing matching the same OD with a 3/4" ID. The closet fit I could find was a 20mm x 32mm x 7mm from AST:
71804C Angular Contact Ball Bearings | AST Bearings
I have a few questions.
First, is there a solution available for shimming the shaft diameter from 3/4 (19.05mm) to 20mm? I haven't seen any specific parts for this. If there are no solutions, I can always exchange the tool holder for a 20mm one, which is even beefier or just buy another one of the correct size. As for the missing 3mm from the width of the bearing, I am considering using thrust washers, thrust bearings and or shaft collars to make up the 3mm difference. Will this work? Is there a bearing bore adapter?
Second, the existing spindle has a 4 tooth 3/8" splined section to allow for transfering torque to the spindle while allowing the quill to retract and extend. I will need to somehow reproduce this mechanism. My current thought is to use a 3/8" square rod stock or cut off the splined section of the existing spindle. I can use a 3/8" to 3/4" coupling to connect the spline to the ER collet. Will this pose any issues as far as connection strength? The 4 tooth spline has the corners rounded over for a better glide into the splined pulley sleeve, but it may pose slop or compromise the holding power. Any ideas? I am open to using to using another mechaism or different size.
Finally, how do I resolve the issue with preload. Are there any solutions available for allowing me to preload the bearings? Given the combined 6mm missing from the bearing widths and roughly 1mm missing from the diameter of the shaft. There should be room for additional components on the shaft. Any ideas?
Thanks.
