586,551 active members*
3,464 visitors online*
Results 1 to 7 of 7
    Sep 2006
    39
    4x8 Laser table?
    Hello, I am looking for a 4x8 laser cutting machine to cut 1/8 aluminum diamond plate for less than 40k. Is there such a thing?
    1880
    i very seriously doubt it as aluminum takes a lot of umph to cut with a laser!
    But I have been wrong before I think? It was so long ago maybe I am wrong about being wrong!
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Smile Punch IT!
    If you are only going to cut aluminum you may be better off with a punching machine. Some of the newer punching systems can punch aluminum faster than any laser.
    Independent CNC Programmer
    www.ctcn.net/~3kings/
    1880
    Thats a good solution.
    Punching machines are actually a lot more versatile than lasers anyway.
    Probably cheaper too but I wouldn't know.
    thanks
    Michael T.
    Sep 2006
    39
    Interesting. I haven't heard of these before. Any links? Thanks for the info guys.
    Oct 2005
    96
    There is a lot used punching machines around example armada, strippit/lvd, trumpf, finn power,
    For 40k i think it is quite impossible to find a decent one except maybe a very old model.
    Do not forget you need punch and die for it which will add in more money for each different set.
    May 2005
    1810
    The punching machines are pretty fast. They are just a little louder than a laser, though.....
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
  1. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  2. HP Laser Jet II/III - RPM?
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-10-2007, 01:20 PM
  3. HX40A Table top Laser
    By bps in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-18-2006, 06:20 PM
  4. CNC laser table
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2005, 05:01 PM
  5. Aligning cnc-table with laser?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 11-17-2003, 04:33 PM
