586,071 active members*
4,360 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > help with Delta VFD-M
Results 1 to 15 of 15
    Apr 2016
    15
    Since I posted this I found a youtube video that shows someone setting the parameters on a delta VFD-M at 1.5 kw and mine is a 2.2 kw. Does anybody know what parameters I need to change for mine? Hi- I just wired my Delta VFD-M to my 220 volt spindle. I see that there are many parameter settings and it says that they are set at the factory but some have to be set by the user depending on what spindle you are using. Can anybody tell me which of these parameters I need to change from the factory settings? Thanks
    Jun 2004
    6618
    Re: help with Delta VFD-M
    I will not be able to help with the wiring or parameter settings, but you need a little more info included. What spindle do you have?
    What problems are you having that the default parameters will not do?
    Lee
    Apr 2016
    15
    Hi Lee- thanks for the reply. The spindle I have is Chinese I believe. I purchased it from UGRA. Its a 2.20 kw/ 220 volt spindle. The problem I'm having is I watched a youtube video and set my parameters exactly like the video then realized the motor in the video was only 1.5 kw and I can't find the parameter to change for my spindle (2.2kw)
    Jun 2004
    6618
    I am not certain, but it may not have that parameter.
    If the VFD is sized accordingly, the actual rating of the spindle might not be critical.
    Have you had to turning yet?
    Lee
    Apr 2016
    15
    I haven't because I thought I might damage something if I started it and a parameter was set wrong. When I first wired the VFD to the spindle it rotated very slowly and I couldn't increase the speed. Since I set the parameters it doesn't spin at all
    15362
    Quote Originally Posted by PaulGB View Post
    Good thinking I wish everyone did this, yes you can damage the spindle if your settings are wrong
    Your VFD and any VFD is never set ready to Run, unless the supplier has preset the Parameters for you, which some times is the case
    The main thing is you know what the Frequency of the Spindle is it 400Hz 300Hz, Amps we can work out Voltage we know number of poles we know, this is the only important information you need as these numbers are what have to be set in the VFD
    Even though there are lots of Parameters that you see in the VFD, there are not many that you need to change
    Mactec54
    Apr 2016
    15
    Its a 400 hz/ 9.70a spindle. I'm using Mach3 software for my CNC
    15362
    I will do a Parameter list for you, be patient, pressing the button too soon can destroy your dream
    Mactec54
    Apr 2016
    15
    Thanks so much. I'm a retired woodworking teacher that has been working on this for years
    15362
    PaulGB
    This will get you running, do the RESET First then set the Parameter in this list, some are Default so don't need changing, I will check if there is anything other Parameters to change later today, just take your time, it's quite easy once you get to understanding the keyboard
    Mactec54
    Pr.76=10 ( This is for Factory RESET )
    Pr.00=00 ( 04 for Pot use )
    Pr.01=00
    Pr.03=400
    Pr.04=400
    Pr05=220v ( Default )
    Pr.10=10 ( Default Adjust to suit Acceleration )
    Pr.11=10 ( Default Adjust to suit Deceleration )
    Pr.24=01
    Pr.26=100
    Pr.27=100
    Pr.37=100
    Pr.52=9 ( Max Amps )
    Pr.148=02 ( Number of Poles )
    ( Auto Tune After these Parameters have been Set )
    Pr.103=02 ( Auto Tune )
    Mactec54
    Apr 2016
    15
    Thanks- I did those changes but I have 2 questions- Pr.00=00 (04 for Pot use) What is pod use and do I have it? the other question is Pr.08=20 when I put that number in it said ERR or error and wouldn't accept that number. Thank you again for your help i really appreciate it.
    15362
    The pot is the knob you turn on the front where the Keypad is, if you don't have it then leave it at Pr,00= 00, some the Pot will still work when set at Pr.00=00 if it does not work then change it to Pr.00=04, the Pr.08=20 can also left at the ( Default Pr.08=1.5 ), this setting is reliant on other settings, so just leave it at default, it won't affect how it will run, I will remove the Pr.08 from the list, it made an error because another parameter needs to be set also, and you don't need the other parameter set
    Mactec54
    Apr 2016
    15
    IT WORKS! Thank you so much for your help. You have no idea how many sleepless nights I had trying to figure it out. Thanks again and good luck to you!
    15362
    I added another Parameter to the list, I'm not sure if you got it or not, this is an important Parameter, Pr.52=9 this is the Amp setting, once you set this do the Auto Tune again
    Which parameter did you use for the Pr,00=00 or 04
    Mactec54
    Apr 2016
    15
    Thanks- I changed Pr-52 to 9 and I have Pr00=04
  1. Wye-delta, delta-wye configurations?
    By mackeym in forum Phase Converters
    Last Post: 07-06-2016, 10:26 PM
  2. delta G41 G42
    By LVX in forum SIEMENS -> GENERAL
    Last Post: 07-18-2011, 09:27 PM
  3. Delta VFD -E help
    By woodguy60 in forum Phase Converters
    Last Post: 03-19-2010, 04:47 PM
  4. Delta Tau
    By Leblondmakino in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-30-2008, 05:07 AM
  5. Delta-Wye (Wye-Delta)?
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 10-09-2007, 10:43 AM
