Hi, Looking to tap the expert knowledge on here again! I can't seem to find specific info that applies to CNC... A lot of information I've found tends to be regarding general woodworking workshops where the chips are usually already loose.
I've been using a 1kW CamVac with a 2.5" inlet and hose but I bought this second hand through convenience at the time. It mostly works (and helps keep workshop dust down with the triple filtration) but it struggles to extract some of the deep wood chips causing a lot of recutting of chips and then heat. I'd like to be able to get at these and I'm not sure which would be best:
- a CamVac with more power
- a different type of system altogether
If I go up to a 2kW CamVac what difference would the hose size make - 2.5" vs 4"? Might this power easily collapse a 2.5" hose and pull the ends out of the vac/machine? I use a custom shoe with a 2.5" push-fit mounting hole and a poly-something skirt (which does need upgrading to brush for a better seal!). I would re-make a shoe to suit 4" (although odds are it would have a hole size much smaller than this at the point of suction where I've 'channelled' the air flow through pockets cut inside of the shoe - which is made from 2 pcs 18mm plywood).
I think I understand correctly from reading around that CamVac's are 'High Pressure, Low Volume systems' - are these better than 'High Volume, Low Pressure' systems such as the big bagged chip extractors for CNC'ing?
(I haven't mentioned cyclone separators because it seems these can just go in-line on vac systems for easier separation and removal of chips).
