586,521 active members*
3,475 visitors online*
    Jul 2004
    22
    General CNC questions
    Hi guys,
    This is my first post here but I have been reading this forum for the last year and a half and have been absorbing all the great information all of you have shared, especially for us newbies - thank you all!
    I have definitely been bitten by the CNC bug and have spent many hours researching machine designs, motion control, etc. About ten months ago I embarked on my own first design for a CNC router that I could use in my woodworking business. I bought an inexpensive 3 axis system from Stepperworld, not so much for production work but mainly as a learning tool. My design worked but wasn't practical because of weight, poor design and inadequate power from the steppers. So I have now started to design a better router system using many of the ideas I have found on this site. I do have a couple of questions though - maybe someone out there can help.
    I purchased the Xylotex 3-axis system with the 497 oz. in. NEMA 23 steppers and plan on running DeskCNC as the control software (mainly because my PC is using Windows 98 OS). I was led to believe that Mach 3 can't run on that OS - is that correct? Does anyone have experience with this control/software combonation and if so, how well has it performed for you?
    I will be using 5/8" - 8 acme lead screws (until I can afford ball screws!) with Delrin-type lead nuts. Can anyone tell me with this configuration what speeds (ipm) can I expect during cutting and rapid?
    I have a ways to go before I actually have the machine up and running. I have a machinist background with some time on some CNC equipment - mostly Maatsurra VMC's as well as 20+ years as a woodworker - both as owner and employee. I own an ENCO mill/drill as well as a full compliment of woodworking machinery so I feel I am somewhat capable of fabricating parts as I go along but by no means am I an expert. This will be a learning process but, that's where the fun is, right?
    Thanks for all your help.
    Dennis
    Mach3 only runs on Win2K or XP, you are correct. For the price of DeskCNC ($350), you could buy a new PC on Ebay and a copy of Mach3.
    As for speeds, could be anywhere between 30-80ipm. It really depends on the particular machine.
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  2. new guy with a cnc lathe general questions
    By LOGBOSS in forum Uncategorised MetalWorking Machines
    Last Post: 05-07-2006, 10:41 PM
  3. General Questions About VS3D / VScad3
    By whelen in forum Jewelry Design Software
    Last Post: 09-17-2005, 11:50 PM
  4. ballscrew repair and some general questions
    By jimbo in forum DIY CNC Router Table Machines
    Last Post: 09-27-2003, 09:48 PM
