I was in the process of installing a coolant pump to a vmc15 that didn't come with a pump and before I plugged it into the outlet i wanted to check the voltage so I typed a m8 at the mdi prompt and checked the outlet and it was reading 120v. Well when I typed m9 to shut it off the voltage only dropped to 109v and not completely off like it should've. Checked the mist outlet with m7 and it was the same way. Could this be the relays beside the fuses or something else?
