Hi all
I have a problem in a matsuura, since it was first installed only it allows manual axis movements but not the spindle, either on MDI allows any movement, this machine is equipped with a fourth axis KOMA and MIDACO APC, both accessories and were eliminated and ignored, I've also tried with the original backup (only 3 axes) with the same result: nothing works in MDI, any program runs, is only capable of movement in manual mode and reaches home position, I looked into the PMC diagnostics screen and seems like the cycle start button and feed hold button are not sending the signal to the controller and i already checked them physically for no continuity or mechanical problem and looks both good,
anyone who has any idea about this problem?
Thanks in advance
