586,106 active members*
2,987 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Change Dimension in F360
    Mar 2013
    344
    In my sketch I made the workpiece thickness 0.375". I need to increase it to 0.750". How can this be done? I tried F360s online help, but found no help. I've tried "push/pull" without success. I know I'm doing something wrong.
    Re: Change Dimension in F360
    You usually create thickness with push/pull, not in the sketch? If you have a dimension in your sketch that shows 0.375", then double click on the number and change it to 0.75.
    If that doesn't work, then I don't understand what you're doing. Pics would help.
    Jul 2016
    4
    Have you checked the Autodesk forum recently? There was a post last night clarifying the difference between push/pull and extrude in both model space and sketch with a screencast.
  1. Change dimension automatically
    By sml2010 in forum Solidworks
    Last Post: 03-02-2015, 07:06 PM
  2. V23 Dimension Help
    By emd68 in forum BobCad-Cam
    Last Post: 06-20-2012, 02:43 AM
  3. dimension 200
    By ricardo yanez in forum Engraving Machines
    Last Post: 06-20-2011, 05:39 PM
  4. Need to know this dimension of DMU 50e
    By NCexplorer in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-21-2009, 11:17 AM
  5. Snap on Dimension
    By keith20mm in forum Dolphin CAD/CAM
    Last Post: 10-13-2009, 05:48 PM
