586,058 active members*
3,347 visitors online*
    Apr 2004
    79
    E-stop and enable outputs
    I need enable 1 to be low and enable 2 to be high during normal operation and both switch during e stop state. Is this a setting or oem code or does this have to be in the macro pump?
    May 2006
    179
    http://www.machsupport.com/MachCusto...le=OEM_Buttons
    set enable in ports and pins
    Regards,
    Kirk
  1. Inputs/Outputs
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 03:52 AM
  2. Opto 22 / ICM outputs not working
    By mzartop6 in forum CamSoft Products
    Last Post: 01-28-2006, 05:35 AM
  3. R20x0 encoder outputs?
    By mecheng10 in forum Servo Drives
    Last Post: 10-06-2005, 03:11 AM
